what is wrong with my fuel????
Old Aug 21, 2002 | 12:24 AM
accordfreak's Avatar
Default what is wrong with my fuel????
ok just lately i've been having choking problems while accelerating. and when my car is idle it sounds like "putt putt" ever few seconds or so. also my inline pump sounds like the fuel isn't flowing constantly and it sounds choppy. i have a full tank of fuel and right now my fuel setup consist of a stock intank pump, FMU, inline pump, and stock injectors. oh and my fuel gauge sending unit is broken so right now it's on E even when i have a full tank. please help... my car feels like it's limping.. thanks!
Old Aug 21, 2002 | 12:39 AM
poison's Avatar
Default Re: what is wrong with my fuel???? (accordfreak)
next mod on your list should be a fuel pressure gauge on the fuel filter to determine what the pressure is and where it should be at
Old Aug 21, 2002 | 12:42 AM
Default Re: what is wrong with my fuel???? (poison)
shouldn't it be at stock fuel pressure with my setup? this problem just happened recently... it didn't do this a few month ago.
Old Aug 21, 2002 | 01:03 AM
poison's Avatar
could be at stock, but it just might be slightly below stock PSI.
when's the last time you replaced your fuel filter
Old Aug 21, 2002 | 01:04 AM
i replaced it around 7 thousand miles ago.
Old Aug 21, 2002 | 01:06 AM
poison's Avatar
wow, hmm, strange.
I would invest in a fuel pressure gauge and see where it sits if your motor is bogging on you.
is there any given RPM it bogs at? or under certain temperature conditions?
also, have you messed with ignition/cam timing at all?
Old Aug 21, 2002 | 01:09 AM
it only bogs when i press the throttle about less than half way. feels like i'm running out of gas or something which isn't the case. i have completely stock timing.
Old Aug 21, 2002 | 09:52 AM
Old Aug 21, 2002 | 12:45 PM
turbod16y8's Avatar
i have the exact same problem. i have a walbro 255lph fuel pum and it sounds lke that too . still cant figure it out either
Old Aug 22, 2002 | 12:09 AM
Default Re: what is wrong with my fuel???? (turbod16y8)
ok my car's gas gauge just decided to kind of work today and my car is running like normal. but what the heck is going on with my car? fuel gauge sending unit? but how could that affect the way the gas flows??? right now my gas gauge is reading 1/4 down from full and i've only driven 25 miles on the tank of gas... please help...
Old Aug 22, 2002 | 05:50 AM
poison's Avatar
I'd get that fuel sending unit fixed, and get a fuel pressure gauge on your fuel filter to determine if your car is getting the right amount of fuel to the engine.
Element3488
12
Nov 19, 2012 08:53 AM
WheaMyRyceGo
May 31, 2009 04:37 PM
sway892
Jun 4, 2004 04:46 PM
DRIVENRacing
May 22, 2004 10:41 PM
