10 psi on 60-1...boy its fast!
I have been tuning like a madman trying to get my car ready to go to the track this weekend, and have been sorting out my mapping on my Haltech. I upgraded from a t3/t4oe w/.48a/r to a 60-1 t3 w/.63 a/r and there is the biggest difference! I am running like 10-11psi on pump gas, stock internals b16a with alcohol/water injection and its soooooo much faster than my old set-up. I have to add a bit more timing up top, and lean it out a bit but right now my car is pulling like mid 12's...hopefully by the end of the night get it pulling like low 12's. I am soooo happy that i switched turbos, there is that much of a difference! And for those that said the 60-1 would be laggy, it pulls very very linear to me, in fact its perfect I get 4-5psi in 1st gear and no wheel spin!
[Modified by boosted hybrid, 11:52 AM 8/21/2002]
Re: 10 psi on 60-1...boy its fast! (SiRkid)
I had a 60-1 on my turbo LS/VTEC setup, at 9.5psi. The car MOVES.
On the video clip in my sig, I was running the 60-1.
New User
Re: 10 psi on 60-1...boy its fast! (B00STeD)
Are turbo's easily upgradable? I have a Drag 3 ITR kit, and I was just wondering if I would be able to switch out my turbo if I wanted to...
is the 60-1 bigger than the t3/t4?
yes!
yes!
Looks like a front page ad !
Damn... T60 ... at what rpm do you high maximum spool in 2nd ?
New User
Re: 10 psi on 60-1...boy its fast! (X2BOARD)
I can't wait to put my 60-1 on my car. I just got one from Boosted3g for like 500 bucks and it's watercooled, and only 700 miles of usage!!!! hope it handles the hp I want.
Re: 10 psi on 60-1...boy its fast! (NoPowerAllRice)
anybody know what trim a t-4e is??
New User
Re: 10 psi on 60-1...boy its fast! (TurbochargedSER)
Hey, with my T3 60-1 I have a goal of about 400-450whp on Race gas, should I stick with the .63 housing or get an .82? and if you say .82 where do I find one?
Re: 10 psi on 60-1...boy its fast! (Pinhead)
I am going to be running at Island dragway on friday night...so if any of you guys are going give me a shout...I will be there, white eg hatchback with black slipstreams on it.
I would go with the .63a/r if you are going a streetable turbo, .82a/r if you are going track car.
I make full boost in 2nd gear at 4800rpm...and when it hits, it hits super hard! Its quite a noticable improvement over my previous turbo.
Out to make some more tuning tonight...hopefully break into 300whp range.
Lates.
Lates.
You may be able to get pretty close to 400 with the .63 A/R Housing, but you will be at the limit of that housing. 450 HP will require the .82 A/R housing. IF you need the housing, I can get it for you! Email me @ louisanaya@hotmail.com
I have been messing around with the T04R's on 2.0 blocks and they absolutly rip. Theya re not that bad with spooling up because it still has a small shaft unlike the T series and it will even out flow a T66.
Re: 10 psi on 60-1...boy its fast! (boosted3g)
Hey boosted3g or anyone, can you tell me more about these T04Rs? I have a 2020cc block and looking to boost around 20psi max....14-17psi street. I was thinkin of a T3 60-1 but I'm looking to at least 400hp, race gas of course, and on the track.. Maybe even go for a T4 60-1. But since it'll be street driven..I'm pretty skeptical on their spool times.
Anyone wanna recommend a turbo or just comment?
Thanks!
Thanks!
Re: 10 psi on 60-1...boy its fast! (gsx4R1)
Wait a minute.... lemme get this straight...
My revhard turbo (well garret but whatever) has a turbin of .62 or .63 forget which) and the compressor is obviously a t4 .53 A/R..... you mean to tell me a t3 60-1 makes MORE power then my specific t3/t4??? that wouldn't make sense since my exhaust is the same size and compressor is larger... please correct me if I'm wrong.
Re: 10 psi on 60-1...boy its fast! (shadowdawn)
its a bigger turbo
[Modified by KAMiN, 8:01 PM 8/21/2002]
Re: 10 psi on 60-1...boy its fast! (T3T4DA6)
Isen't a t3 of any size pretty much the same size as my turbine housing on both sides (turbin and compressor on say a T3 60-1 or not)?
joepiscapo_83
01-22-2005 08:45 AM
Anyone running a straight t3 on a b18? How is your spool up? Whats the max boost i could push on a t
96EkTurboHatch
12-25-2004 10:16 PM
juggernaut
04-06-2004 02:53 PM
