Engine Tuning and 15psi
Old Aug 23, 2002 | 07:03 PM
td04civic's Avatar
Default Engine Tuning and 15psi
I'm currently building a d16z6 to run 15 psi. Do you think a V-Afc and a MSD BTM would be enough to tune the fuel and ignition timing?
Old Aug 23, 2002 | 07:17 PM
rjardy's Avatar
Default Re: Engine Tuning and 15psi (td04civic)
no
you will want to go standalone if your seriouse about it
Rob
Old Aug 23, 2002 | 08:11 PM
ekb18c's Avatar
15 psi? On vafc and btm? On a stock ecu? I'm sure you can get away with it for a little bit, but I wouldn't! Even if you got 15 psi to run somewhat good on a vafc and btm, it wouldn't run as good as if you had a standalone ecu. (Eg. Hondata.. etc.. etc. )
sfjdmlud3
May 27, 2004 11:21 AM
Champ R
Nov 21, 2003 03:26 PM
SlamMan
Jun 16, 2003 09:54 PM
td04civic
Nov 26, 2002 09:48 PM
1.8T_EG
Aug 29, 2002 12:13 PM
