Has anyone ever done this?
Old Aug 21, 2002 | 10:31 PM
SlowB16's Avatar
Default Has anyone ever done this?
I was thinking of putting a coat of that truck bed liner stuff in my engine bay. It is all nasty looking in there and there is paint chipping up everywhere. Does anyone see any problem to this? Is it ok for that stuff to be in an engine bay where it would be very hot? And I was also thinking that the heat might not disperse from the engine bay because of the thickness of the bed liner, but I could be wrong.
It seems like this stuff would work well because you would never have to worry about it scraping off when you are tinkering under the hood so that is why I ask....
and I have this in this forum because I have a turbo and I figure the incresed temperature might effect it, but I could be wrong there as well....
thanks in advance
[Modified by SlowB16, 7:34 AM 8/22/2002]
Old Aug 22, 2002 | 12:36 PM
SlowB16's Avatar
Default Re: Has anyone ever done this? (SlowB16)
up because I am bored
Old Aug 22, 2002 | 12:38 PM
b18bturbo's Avatar
should work just fine... but make sure you clean the surface before applying this bedline stuff it s very tricky on a dirty sruface.
Old Aug 22, 2002 | 12:39 PM
SlowB16's Avatar
Default Re: Has anyone ever done this? (b18bturbo)
yeah that is what I figured. thanks alot!!
Old Aug 22, 2002 | 12:48 PM
CovertFI's Avatar
i was thinking weight might be an issue with this stuff but then again it will be in the front so it might help. i dont see a down side, other than i hope you dont want to ever paint it again, i am sure that **** is hard to take off.
Old Aug 22, 2002 | 12:50 PM
SlowB16's Avatar
Default Re: Has anyone ever done this? (CovertFI)
It will be a little heavy, but a few punds isnt going to kill me. I just want it so I wont have to worry about scratching the paint off under there
Old Aug 22, 2002 | 04:06 PM
PrecisionH23a's Avatar
make sure you ask the people how much heat the material can endure before it fails. let us know how it turns out.
Old Aug 22, 2002 | 04:28 PM
speedworks's Avatar
Default Re: Has anyone ever done this? (GudeH23a)
it is extremely heavy and near impossible to remove
Old Aug 22, 2002 | 05:21 PM
SlowB16's Avatar
Default Re: Has anyone ever done this? (speedworks)
Im never going to remove it. My engione bay is nasty. This will cover the funk.
Old Aug 22, 2002 | 05:41 PM
hatchy's Avatar
You may want to call the LineX or Rhino and check to see what happens to the material when it get hot.... you don't want toxic fumes leaking into your cabin while you drive. I have this stuff on my truck and it kicks ***, but I am not sure what happens when you put it next to a hot manifold for a few hours.
etnies
21
Dec 30, 2014 02:36 PM
sl0wDA9
Paint and Body
Dec 22, 2009 11:51 AM
rubens
Jun 1, 2004 09:57 AM
Pikachu
Nov 25, 2003 11:52 AM
