Gasket material?
Old Aug 22, 2002 | 07:50 AM
speedymon's Avatar
Default Gasket material?
Can i use that gasket material they sell at auto parts stores to make my own gaskets for my turbo kit? Just wondering if the material can take high temps.
Old Aug 22, 2002 | 12:42 PM
speedymon's Avatar
Default Re: Gasket material? (speedymon)
ttt
Old Aug 22, 2002 | 12:49 PM
b18bturbo's Avatar
it will burn up you need metal type gasket or no gasket at all.
Old Aug 22, 2002 | 12:51 PM
SlowB16's Avatar
Default Re: Gasket material? (b18bturbo)
There is only the gasket for the turbo to manifold, and for the wastegate to manifold right? And you dont want that rubber **** on the manifold, it will burn!!!!
Old Aug 22, 2002 | 04:04 PM
PrecisionH23a's Avatar
Default Re: Gasket material? (SlowB16)
luckily where i worked this summer i stole some grapholock from the stock room, its used on all the boilers and turbines that go up to 2200degrees... i figured this would be suitable for my custom 3" exhaust...
Old Aug 23, 2002 | 12:59 PM
speedymon's Avatar
Default Re: Gasket material? (GudeH23a)
yeah i kinda figured the rubber ones would burn. I was thinking of the paperish type gaskets. I don't know what material it is. I'll check again to see if the Drag kit came with a gasket for the turbo and mani. What about the dp and turbo? Do those pieces need a gasket between them?
B16Civic93
Mar 12, 2005 09:00 AM
b18Gooch
Feb 9, 2005 12:56 PM
VtecAdil
Oct 16, 2004 09:40 PM
1.8T_EG
Sep 12, 2003 07:00 PM
R-1303
May 19, 2002 03:09 PM
