fuel pump relay
wat does this diagram mean?? im goin to get an inline upmp..i dont undestand wat the diagram is of or means??
also why not just let it run wit 12v and have constant pressure?? is it bad for the motor?
Because it needs to turn on and off with the regular fuel pump so that it only runs when the car is running. The power wire for the inline pump needs to be bigger than the power provided by the signal wire, so a relay is used.
I think he means where is the relay to tap. Its in the drivers side kick panel. I dont have my digi cam but ill try and find you a pic.
its a grey box half the size of a box of cigarettes under the driver side dash closer on the door side. its mounted by a small bracket. Tap the red wire of the fuel pump to pin 7 i belive.
hondaluver12
Jan 30, 2012 02:37 PM
insomniac791
Jan 22, 2004 04:23 PM
