Where to get TD04 exhaust flange?
Anyone know where I can pick up a TD04-15G exhaust flange? I need one for a custom downpipe. I know there's some DSM place somewhere that has them.
Hell, I think the T25 turbine may even have the same bolt pattern...
Thanks a lot,
- Slater
Thanks a lot,
- Slater
Re: Where to get TD04 exhaust flange? (Slater)
You just need the one that goes between the turbo/DP?
Try like a Napa store. I work at a small one, and that's where I got mine (Today actually). They should have a selection of them in Felpro brand hanging on the wall. There will probably be one that will line up w/ the middle pipe and the 3 holes.
jB
jB
Re: Where to get TD04 exhaust flange? (PeloTudo)
Felpro? I thought they only made GASKETS? I need the metal FLANGE for welding up a custom downpipe.
Unless you DO mean flange - then my bad and I'm off to NAPA tomorrow!
- Slater
- Slater
are you planning on using the internal wastegate? or are you going to go to an external and need to block off the wastegate port with the flange? if you are going to block it off and it is a 5bolt discharge, we have them for sale in the flanges section at http://www.peakboost.com
thanks
hope this helps
thanks
hope this helps
Looks like...
this:
4-bolt exit flange, and I am going to use the internal WG.
I *think* TD05 flanges would work (from most DSMs), but I am not sure. Geoff might know...
- Slater
[Modified by Slater, 2:48 AM 8/23/2002]
- Slater
Re: Looks like... (Slater)
im sabah
09-27-2004 03:24 PM
