PowerFC knock indicator/way to test knock sensor?
Old Aug 22, 2002 | 09:13 AM
brian b's Avatar
New User
Default PowerFC knock indicator/way to test knock sensor?
has anybody ever seen the knock reading say anything except 0? i have a 2000 civic si w/ turbo, it has a knock sensor but I'm thinking either a) it doesn't work or b) the powerfc just doesn't read it..
Old Aug 22, 2002 | 02:14 PM
boosted3g's Avatar
Default Re: PowerFC knock indicator/way to test knock sensor? (brian b)
The FC will read the knock sensor.
Old Aug 22, 2002 | 02:58 PM
MiraiZ's Avatar
Default Re: PowerFC knock indicator/way to test knock sensor? (boosted3g)
yup...it should always fluxuate even if the engine is not knocking...
Old Aug 22, 2002 | 03:07 PM
Austin's Avatar
That is unless you have the PowerFC for the B16B...I was told that it didn't support a knock sensor input...
I always had some sort of reading on the knock sensor...no real problems unless it went over a certain number(can't remember what, as it's been a while).
Austin
Old Aug 30, 2002 | 03:00 PM
RICHJ's Avatar
Default Re: PowerFC knock indicator/way to test knock sensor? (Austin)
Austin
60 I think, then it will flash the CEL at you.
Old Aug 30, 2002 | 03:10 PM
brian b's Avatar
New User
Default Re: PowerFC knock indicator/way to test knock sensor? (HardHead42)
yeah mines for the b16b.. i've seen the cel once at the track in 4th gear at 8300rpm, i was pretty sure it was from injector duration so i raised the fuel pressure and dropped the injector # a bit and i haven't seen it since
(hey thanks for bringing this topic back to the top, i completely forgot about it)
co_OlLo_OdDo_Od
May 3, 2006 11:36 PM
DumpedSi
Aug 10, 2003 08:30 PM
