Daily Driver Turbos
Old Aug 22, 2002 | 12:51 PM
GSR95TEG's Avatar
Default Daily Driver Turbos
How often do you have to not drive your turbo daily driver because of misc. problems and what not, over the course of a year? Also what are common problems that you encounter??
Old Aug 22, 2002 | 12:52 PM
b18bturbo's Avatar
Default Re: Daily Driver Turbos (GSR95TEG)
i drove a turbo b18b over 2year consistent 10 miles easy way to work and 15 miles to school. i never had a problem just change oil regular maintaince and you should be just as good as factory if the install is done right.
Old Aug 22, 2002 | 12:59 PM
GSR95TEG's Avatar
Default Re: Daily Driver Turbos (b18bturbo)
so what happened after 2 years detonation? sold it?? Just curious, Im slowly piecing my kit together. I have second thoughts sometimes(like today)
Old Aug 22, 2002 | 01:00 PM
DA666's Avatar
my car is daily driven with a custom kit...so far no internal problems yet....but i do somthing to it at least two nights a week its off the road for misc stuff...ie new couplings...oil feed leaking oil return leaking...oil return flange off the turbo leaking...like that....bad part about it is that to get to the return properly u have to take out mr rad. wg, fan, sometimes even downpipe too....its real tight...like all hondas with big mannys and big turbos, no room to work on them
Old Aug 22, 2002 | 01:09 PM
GSR95TEG's Avatar
Default Re: Daily Driver Turbos (T3T4DA6)
Thanks man good info! That is been copied to my notepad Any other experiences/advice from the wise FI forum?
Old Aug 22, 2002 | 02:01 PM
b18bturbo's Avatar
sold it.. customer still used the car for another 2 years before he blew it up.
Old Aug 22, 2002 | 02:04 PM
TheShocker's Avatar
It probably only blew up because he turned up the boost without compensating the right amount of fuel/timing etc. He didn't tune it. If the car is tuned right, it could last many years.
Old Aug 22, 2002 | 04:28 PM
XforgivenX's Avatar
New User
InlinePro installed my Drag III kit on my 94 GSR around 13 months ago. Along with the kit, I got 440cc injectors, larger fuel pump, afc, and a lower compression headgasket. I've been boosting 10lbs daily for 13 months and I haven't seen a single day of down time except for the 4 days I didn't have my car because I was getting a Hondata installed/tuned. The car now has 130,000 miles on it, and still runs perfect. Oh, and my commute to work is half an hour one way. The only problem I can think of, is my stock motor mounts aren't as strong as they need to be and the fitting on the top of my wastegate was rubbing against the hood when I drove the car hard. This caused the vacuum line to come loose. I have since replaced the vacuum line, the fitting, gotten motor mount inserts and notched out some of the webbing of the hood.
Old Aug 22, 2002 | 05:40 PM
DIRep972's Avatar
Smarter than you
My car is daily driven and daily raced. 89k miles total. 15k miles boosted. I drive about 2k miles per month. 8psi daily. the only time i go under the hood anymore is to change plugs and do an oil change. just did compression test last week, 185,190,180,180
dont be scared to turbocharge ur daily driver. with a reliable install and reliable parts it should behave just like a stock car.
sasinorm01
Jan 10, 2015 02:39 PM
Ntrpriz
Jun 29, 2003 08:10 PM
darkracer
Apr 23, 2003 08:09 PM
Scylla
Mar 19, 2002 12:20 PM
sa21199
Oct 12, 2001 08:44 AM
