forcing a wastegate open?
Old Aug 22, 2002 | 08:56 AM
brian b's Avatar
New User
Default forcing a wastegate open?
I'm looking to tune my car for daily driving without boost, how can I lock the wastegate open so the turbo doesn't spool? and would this be bad for the turbo (over revving?)
I have a Tial 40mm wastegate, and a Blitz DSBC boost controller.
Old Aug 22, 2002 | 09:39 AM
ninesecrx's Avatar
Default Re: forcing a wastegate open? (brian b)
take the wastegate off.
Old Aug 22, 2002 | 09:45 AM
brian b's Avatar
New User
Default Re: forcing a wastegate open? (ninesecrx)
and do what with the exhaust gas? im trying to drive/tune the car in this condition
Old Aug 22, 2002 | 09:46 AM
Speed PHreak's Avatar
Remove the spring
Old Aug 22, 2002 | 10:07 AM
Etylorcen's Avatar
Default Re: forcing a wastegate open? (Speed PHreak)
Why would you want to tuen your car w/o boost if you're turbo?
Old Aug 22, 2002 | 10:11 AM
GSRwBOOST's Avatar
Default Re: forcing a wastegate open? (Etylorcen)
uh.... put in a really small spring.. and leave your boost controller off..
but we all know you wont "leave it off" because, common your not bullshitting us... your gonna run it on the most psi you think is safe...
I was there with you like so many before you... I won't run that much boost unless i'm racing....
1.5 years later my EBC is STILL set on 10psi....
hahahahahahahahahaahahahhahaha
Old Aug 22, 2002 | 11:17 AM
brian b's Avatar
New User
Default Re: forcing a wastegate open? (GSRwBOOST)
the reason i want to tune it this way is because a friend drove my car that has a 2000 civic w/ i/h/e and his car responds alot better in daily driving.. ive been on the dyno for a bunch of hours tuning the top end (14psi) and now i'm trying to tune the midrange.
Old Aug 22, 2002 | 01:59 PM
ninesecrx's Avatar
You asked what to do with the exhaust...well whether you took the wastegate off used a smaller spring(it would still boost) or proped it open somehow...your still gonna have open exhaust. Thats all a wastegate does, regulates exhaust. Thats why there is no real answer unless you have a dump tube that goes back into exhaust piping.
Old Aug 22, 2002 | 05:07 PM
st00pid's Avatar
If you force the wastegate open, the exaust energy bypasses the turbo and the turbo doesnt spin as fast.. if you tune it that way and run the wastegate normally, you will run VERY lean and will buck and be very hard to maintain a constant speed.
You should just tune the mid range while driving the car
jason
Boosted00
Jan 19, 2018 01:51 PM
V-SPEC 1
Feb 19, 2013 07:43 PM
richboi
Apr 15, 2007 07:46 PM
turbodan4
Mar 7, 2006 09:09 PM
GruvyTune
Apr 23, 2002 07:08 AM
