B-Series Turbo Parts list
Ok i tried doing a search for a turbo kit parts list.. basically im looking to put together my own turbo kit but i need to know everything that i will need... im not a newbie but i just want to make sure that im not forgetting anything..
Thanks
Thanks
Re: B-Series Turbo Parts list (fbp_gizzer)
1. Turbo manifold
2. Turbo
3. Wastegate
4. Turbo DP
5. WG dump tube
6. Intercooler Piping
7. Intercooler
8. FMU if you use it or some form of larger injector setup.
9. Fuel pump
10. Oil line kit drain and feed
11. Hose Couplers
12. Clamps
13. Missing Link/ OR some type of MAP control device
14. BOV
15. AIR FILTER
thats pretty much it..
2. Turbo
3. Wastegate
4. Turbo DP
5. WG dump tube
7. Intercooler
9. Fuel pump
11. Hose Couplers
12. Clamps
14. BOV
15. AIR FILTER
I am kind of confused about fuel management. If you have Hondata, you dont need a fuel pump or fmu? What about the map sensor? Should you use larger injectors with Hondata, or will it just increase pulse width with the stock 240cc injectors? Sorry, the fuel stuff has been bugging me.
Re: B-Series Turbo Parts list (ricodemus)
hondata with larger injectors 3 bar map sensor and factory pump work just fine as slong as you dont go overboard on fuel pressure.
The stock map is only good to11psi or so. after that you would need some type of map sensor that can handle larger boost levels.
[Modified by b18bturbo, 3:37 PM 8/22/2002]
Stopsign32v
04-08-2011 12:07 PM
Tr0LL
08-30-2001 05:51 PM
