sohc people @ what rpm do you hit full boost and with what turbo ?
Old 08-22-2002, 02:46 PM
tysf's Avatar
Default sohc people @ what rpm do you hit full boost and with what turbo ?
im wondering how much i'm going to have to spend to get something that can spool at around 3000-3500 and still be decently efficient pushing say 10 psi at 7k rpm
im still a turbo newbie but can i get that kind of performance from something cheap like a dsm turbo or do i have to step up to something more spendy like a ball bearing turbo?
Old 08-22-2002, 11:34 PM
jdblack1's Avatar
Default Re: sohc people @ what rpm do you hit full boost and with what turbo ? (tylerspec)
Open compressor inlet, open wastegate and no downpipe.
14b, D16A6
I had 5 psi at 3000 all the way up. I had it regulated to 5psi but my wastegate hose blew off and I had 12psi in second gear at 6500
That'll scare the **** out of you. On a fully stock motor
Old 08-23-2002, 02:56 AM
DSF
DSF's Avatar
Before I took it off...
T-25, @8.5:1CR, SOHC non-VTEC, 7psi @3200 / 10psi @3500
Old 08-23-2002, 04:42 AM
New User
RGAZ's Avatar
T25 D16A6 5 psi @ 3000, 10 psi @ 3300. 2.5" mandrel DP. Need boost controller for clean boost above 5500 though. The wastegate spring is too weak to hold the pressure back at that rpm.
Randy
Old 08-23-2002, 06:27 AM
VTC_CiViC's Avatar
Default Re: sohc people @ what rpm do you hit full boost and with what turbo ? (RGAZ)
In what gear are you guys getting this boost? I'm noticing more and more than my GReddy takes forever to deliver good boost on my Civic, like not untill 5k rpm do I have full boost in 2nd or 3rd.
Old 08-23-2002, 06:54 AM
New User
PyroVTEC's Avatar
Default Re: sohc people @ what rpm do you hit full boost and with what turbo ? (VTC_slow_CiViC)
My Greddy kit on my SOHC hits full boost by 3800 indicated RPM in 2nd... 1st comes a little bit later...
Old 08-23-2002, 06:55 AM
Trac226's Avatar
usually in 2nd and 3rd i'll get 6.5 psi @ 3500
CovertFI's Avatar
t3/t4 .50a/r compressor .48 a/r turbine spoolin at 3k finished at 4k (well more like 3.5k) @ 5psi
Old 08-23-2002, 07:08 AM
DSF
DSF's Avatar
Any gear above 1st (which is to short to look at both boost gauge and tach).
Old 08-23-2002, 07:52 AM
WhiteSTi's Avatar
Default Re: sohc people @ what rpm do you hit full boost and with what turbo ? (DSF)
I get full boost (7 psi) on my T3/T4 bb at 4000. Not sure of the turbo specs though.
Old 08-23-2002, 08:26 AM
jdblack1's Avatar
Default Re: sohc people @ what rpm do you hit full boost and with what turbo ? (BoostedEX)
I had no boost it first gear. it was too short.
Old 08-23-2002, 10:19 AM
glagola1's Avatar
I'm running the Apexi ball bearing kit and I get full spool (6.5psi) at 2700 in fourth gear. I don't know how quick is spools in first (I have to watch the road) but I think it's by 2500 at least. I'm running a 2-1/2" thermal with 2-1/2" cat.
It spools way faster than my old Greddy TD04. It also doesn't run out of breath at redline. Much, much, much better turbo than the greddy.
Prelude_5g00
08-28-2011 04:36 PM
Markb16a
29
01-10-2008 01:25 PM
BlownBlackSi
11-07-2005 08:28 PM
3k9civic
10-03-2005 12:02 AM
FUP23
09-30-2002 09:15 PM
Quick Reply: sohc people @ what rpm do you hit full boost and with what turbo ?
