timing issue
Old Nov 1, 2009 | 01:53 PM
heeltoehonda's Avatar
Default timing issue
i have a 95 b18b. i timed the engine with the dizzy centered. it was way off. im thinking that this might be my issue with all the hesitation in my engine. i moved the dizzy so it went towards the radiator(front of the car) and the timing got even worst. so i then moved it the opposite direction(all the way) towards the firewall and the timing got the best its been. but im still not perfect. im a good inch or so off. if your looking at my engine when the headers are closest to you and the I/M is farthest. the timing mark on the pulley is lower than the pointer on the plastic. my question is what would i do to fix this? i cant make anymore adjustments with the dizzy because its turned all the way. so do i need to move the timing belt again? maybe im still a tooth off? i think this will fix my lagging/hesitation problem when i get the timing correct. let me know if you guys have any imput. i would greatly appriciate it.
Old Nov 1, 2009 | 02:39 PM
GagnarTheUnruly's Avatar
Default Re: timing issue
I think your engine timing must still be off if you can't advance to 16 deg. You've jumped the connector in the passenger footwell and let the engine warm up, right?
Old Nov 1, 2009 | 05:50 PM
509forcfedcivic's Avatar
New User
Timing is off. There are alignment holes on the cams and cam caps, so just insert a small punch or some thing into each one, make sure the crank is at tdc, slide the belt on and you should be golden.
Old Nov 1, 2009 | 06:07 PM
Dcteg94's Avatar
Agreed, you should set your crank to TDC and then properly align your cam alignment marks. Then just slide your timeing belt back on and you should be good.
Old Nov 1, 2009 | 07:26 PM
yeah i let the engine warm up to runing temp and then jumped the service check connector. the service check connector is the one with 2 wires not 3 right? i think i need to adjust the timing belt still.
Old Nov 1, 2009 | 07:28 PM
ok thanks . i didnt know that. i lined up the 2 little marks on the cam gears but i still must have been off a tooth or so. i'll do that tomorrow and see how it goes
Old Nov 1, 2009 | 07:30 PM
LuDog's Avatar
im having the same issue with mine 95 coupe b16a2 but i got a bad knock sound someone help me out watch my video. Thanks
<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/VR3dPQlGC88&hl=en&fs=1"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/VR3dPQlGC88&hl=en&fs=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>
Old Nov 1, 2009 | 07:31 PM
LuDog's Avatar
sorry i ment this thanks
http://www.youtube.com/watch?v=VR3dPQlGC88
Old Nov 1, 2009 | 07:57 PM
Originally Posted by LuDog
i click on it and it says the video i have requested is not available
Old Nov 1, 2009 | 08:43 PM
tiresias's Avatar
I wish I could say the same when we did the whole head resurfacing on my car. The belt tensioner lost it's tension. We had to push the tensioner manually and tighten it. The tooth kept skipping when we hand-crank the engine to see if the tension was firm.
But definitely redo the timing belt. Set the cam gears pointing up and the pistons on TDC. To keep the cams from spinning, put a small rod through the first shaft retainer's hole. Put everything back together. Dont forget to get use the timing gun to get an exact reading on where your dizzy should be.
You should be good after that.
Old Nov 2, 2009 | 06:18 AM
thanks
Old Nov 2, 2009 | 10:56 AM
i just got done working on my car. and i got her fixed!!
i was one tooth off. i adjusted the timing belt, put everything back together, started her up, timed the engine and she runs like a champ!
thanks everyone for your advice
fastrat37
Dec 24, 2012 03:49 PM
dem0nk1d
Jun 27, 2012 12:39 PM
ascarberry
Apr 21, 2011 03:46 PM
mortificationrock
10
May 8, 2008 01:51 PM
400whp
Dec 9, 2003 02:10 PM
