Interior
Old Nov 1, 2009 | 12:52 AM
JDMkid98ls's Avatar
Default Interior
I was stripping my tan interior today in my 98 and when I went back to put in the black passenger back panel that goes from the back seat to the trunk...IT DIDN'T FIT!
I noticed that on the tan panel that was in there had a piece cut out that looked like someone did them selves in order to have the panel fit.
Does anyone know what I am talking about? The panel is from a 96 and i'm putting it into a 98. Maybe any body alterations between the generations?
Old Nov 1, 2009 | 01:15 PM
berb_15's Avatar
Default Re: Interior
Yes I had the same problem. That black metal brace on the floor apparently isn't in every model integra. I just used a dremel to shave the new panel down. It fit good and you couldn't see the cuts. Hope that helps.
Old Nov 1, 2009 | 04:04 PM
JDMkid98ls's Avatar
Yeah it does, thanks
Old Nov 1, 2009 | 06:43 PM
andrew54's Avatar
The bar is only in 1998-01 the panel you got must have been out of a 94-97
Old Nov 1, 2009 | 11:31 PM
JDMkid98ls's Avatar
Yeah it was out of a 96...I didn't think there was much of a difference. Is there anything else I should know about before going deeper into this project?
Old Nov 4, 2009 | 05:06 PM
berb_15's Avatar
I've heard this before but mine's a 97 and has it.
Old Nov 4, 2009 | 05:08 PM
berb_15's Avatar
An to the op, the only other surprise I found is that some models have tweeters on the door panels and some don't. If you buy a set usually you don't have to worry about it. I bought mine from two different integras and one had a tweeter and one didn't... other than that everything else is a strait swap.
bluemax189
Mid-Atlantic (Sales)
Aug 8, 2014 03:40 AM
cleanazcoupe
May 27, 2009 10:26 AM
98GSRDC2
Jun 8, 2008 05:29 PM
DreamCatcher
13
Mar 8, 2006 08:21 PM
