automatic engine harness on a manual, will it work?
Old Nov 5, 2009 | 05:31 PM
turbojdmsol's Avatar
Default automatic engine harness on a manual, will it work?
so i have a b18c and i recently got an automatic LS engine harness. I already wired up vtec and its good to go. My question is what will need to be done to the automatic harness to work on my manual tranny, anything?
the b18c is obd2, and so is the LS harness
thanks for any help!
Old Nov 5, 2009 | 06:14 PM
TonySemi's Avatar
Default Re: automatic engine harness on a manual, will it work?
I have a similar question... I have a 97 hatch with a 1.5 automatic, Im swaping in a 1.6 Sohc manual trans. I have already done the 5speed conversion,pedals, slave, master,ect... Question is .. Do I need to change the harness or will it work? THANKS
Old Nov 6, 2009 | 07:36 AM
im guessing we are going to have to run a neutral safety switch and the back up light wire
Old Nov 6, 2009 | 12:37 PM
TonySemi's Avatar
you are def right. The automatic assy contained all that, but Im more concerned with the engine side. I dont think there's a diff, but thats why im asking. Hopefully someone will give us a better idea.
Old Nov 6, 2009 | 09:43 PM
God-Driven's Avatar
I never done this conversion but more likely you are going at have extra plugs, the auto intake has an egr and the manual doesnt, also like you said the back up switch might be diffrent but I'm not sure.
Old Nov 6, 2009 | 10:27 PM
PaulMc's Avatar
Painfully Stupid
The automatic wiring harness doesn't have a VSS plug that manual trans use to clock speed. I'm sure it should work in terms of being able to start the car and drive it, but I'm sure it wouldn't be 100% as if you had the correct EWH for it.
gruntor
Jun 3, 2013 02:46 PM
slvrslepr
Mar 23, 2009 02:58 PM
stackz
Sep 5, 2007 09:06 AM
MadCityLude
Aug 1, 2006 07:42 PM
