HELP! brake light problem!
Old Oct 28, 2009 | 03:41 PM
vesnarrgh's Avatar
Default HELP! brake light problem!
i have a 91 integra & my brake lights doesnt come on. here's the full story. everytime i place a 20 amp fuse in the horn/brake it burns and at the same time as im applying the brakes my car shuts off. and i notice a burning smell. HELP! any info would be appreciated.
Old Oct 28, 2009 | 04:03 PM
bunnyhatch93's Avatar
Default Re: HELP! brake light problem!
You gotta short somewhere.... I would start at the taillights and see if a wire is bare then go from there.
Old Oct 28, 2009 | 04:27 PM
vesnarrgh's Avatar
^^well there's nothing wrong with the wiring & its new bulbs. im just wondering why the car keeps cutting off.
Old Oct 29, 2009 | 03:38 AM
Obviously there is a wiring problem somewhere. Check your engine grounds and battery ground........
Old Oct 29, 2009 | 05:36 PM
Sam-DB8's Avatar
Bust out the factory service manual and check whatever goes to that fuse. You might also check above/around the brake pedal and see if anything is getting pushed on when you apply the brakes.
Old Oct 29, 2009 | 06:51 PM
vesnarrgh's Avatar
ok ill get to it in the am because its dark outside. ill let you guys know what's up.
Old Oct 29, 2009 | 07:57 PM
skthx's Avatar
disconnect your negative from your battery then put in the fuse
aktc167
Jul 14, 2007 02:48 PM
HybriDNA
Dec 16, 2003 08:18 AM
HybriDNA
Dec 7, 2003 07:14 PM
CIVIX
11
Feb 27, 2003 03:51 PM
Flamenco-T
Feb 4, 2003 07:39 PM
