Fuel pump problems? help!
Old Nov 5, 2009 | 08:01 PM
4dooritr's Avatar
Default Fuel pump problems? help!
Hey fellas,
I have been having some problems lately when starting my car, if I turn the key right away and crank the engine it starts up but then dies, next try it runs perfect.
Fuel filter isnt that old, fuel pump about a year old. 7-8K miles on it
If I allow it to fully prime the pump it starts first try but has a slight hiccup. fuel pump showing signs of last days?
Fuel pump is a Walbro 190LPH. It whines at idle but has a different pitch of sound with throttle positions, sound pitch gets deeper while the throttle goes down. this normal?
Old Nov 6, 2009 | 02:08 PM
sixfourkiller's Avatar
Default Re: Fuel pump problems? help!
Originally Posted by 4dooritr
Hey fellas,
well first to help find out the problem what year is your integra to know if its workin off an obd1 or obd2. and did u have a check engine light on
Old Nov 6, 2009 | 09:31 PM
God-Driven's Avatar
you might have a bad injector leaking inside the cylinder or a bad pump and thats why it takes a while for the fuel to travel all the way from the tank to the injector, the best way to find out is putting a fuel gauge and let the car seat over night and crank it, the needle should go all the way up as soon as you turn the key, if it takes a while then you have and internal leak, pull the plugs out and see if theres any fuel inside the cylinder, also the check valve inside the pump could be bad and all the fuel is going back to the tank
Old Nov 9, 2009 | 06:06 PM
Dcinno's Avatar
my car does the same thing its because the car gets too much fuel at one time
EJ8CIVIC
Jul 5, 2015 12:07 PM
Chris del sol
Apr 16, 2013 10:42 PM
Obama
Texas -OK -LA (Sales)
Oct 28, 2010 12:18 PM
Obama
Aug 12, 2010 01:22 PM
nsone
May 14, 2009 04:35 AM
