Dizzy question, code 4,8,9
Old Oct 27, 2009 | 11:09 PM
kaddi88's Avatar
Icon2 Dizzy question, code 4,8,9
Just gettin ready to finish my LSV build and i decided to check on my dizzy on a friends car. When i check the codes it sends out 4,8,9. The car starts fine, but idles at 2k RPM's or higher. Last time i had dizzy problems like this the car wouldnt even start. Would these codes make it idle high?
My other question is i have a different Vtec Dizzy, it has some red jdm like writing on it, im confused on the rotor shaft, it is smaller than a regular rotor. I tried putting a new rotor on it and it was too big. Also this dizzy does not produce a spark (the rotor looks to be ok, but might as well be replaced the cap is also fine) i think it was throwin code 9 in my face... ill try and post a pic tomorrow.
Any info on either of these two problems let thatd be great.
Old Oct 28, 2009 | 10:32 AM
kaddi88's Avatar
Default Re: Dizzy question, code 4,8,9
bump
Old Oct 30, 2009 | 07:13 PM
kaddi88's Avatar
help needed tried a new dizzy and still same codes checked wiring everything seems good. ECU?
Old Oct 30, 2009 | 07:31 PM
kchungb17a's Avatar
Have you tried a USDM dist? Is the ECU JDM or USDM? The codes you posted are all from sensors that I believe should be in a USDM dist but I don't know enough about JDM dist to know if they should have the same sensors.
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/part-2-obd1-code-check-list-2568406/
Also, note that it says "loose wire" at the sensors. This can be just that or a failing sensor/dist.
monster d
Jun 12, 2013 10:20 PM
cd5tuner
Jul 23, 2012 02:36 PM
nitewolf
Oct 26, 2009 04:53 AM
bad-monkey
Sep 23, 2004 05:13 AM
ludelvr
Jul 18, 2004 04:50 PM
