Type R wing
Old Oct 31, 2009 | 05:10 AM
njmad's Avatar
Default Type R wing
ok so i got a 97 integra gsr and it has the gsr wing on it but i would like to put a type r wing on the back. So the question is does it use the same hole on the gsr wing to the type r wing ? I DONT want drill new holes.
Thank for the help
Old Oct 31, 2009 | 06:09 AM
mouab18c1's Avatar
Default Re: Type R wing
direct bolt on. no drilling needed, you'll just loose your third break light since the ITR wing does not have it
Old Oct 31, 2009 | 12:09 PM
Zappythebum's Avatar
There will be a larger diameter hole left over after swapping the spoiler for the ITR wing, this is the hole that the wiring for the third brake light in the old wing passes thru, which they do sell plugs for from acura i believe
Old Oct 31, 2009 | 01:58 PM
TheFyget's Avatar
^ correct there is two holes on one side and three on the other, the type r has no third on the one so there will be need of a plug. this hole is almost not even visible, it sticks out about half way from under the wing. the plugs do just fine.
Old Oct 31, 2009 | 03:12 PM
SisterFister's Avatar
cheapest typeR wing i think or seen so far:
http://www.hmotorsports.com/
bought mine and it came in 2 days
Old Oct 31, 2009 | 11:03 PM
ej1love's Avatar
i can confirm it does not have the same mounting points...
Old Nov 1, 2009 | 06:02 AM
njmad's Avatar
well why does one people say it does not fit has any body really done this ??
Old Nov 1, 2009 | 06:31 AM
XslickwhitetegX's Avatar
^Cause he doesn't know wtf he talking about! Its a direct bolt on, but like stated above there will be a small hole (from gsr wing wires) which can be easily pluged up.
Its on of the most popular exterior mods for g3 teg.
Old Nov 1, 2009 | 08:12 AM
mouab18c1's Avatar
alright i have one on my 97 gsr. stock OEM Itr wing onto a gsr. direct bolt on and yes there will be a hole for the wires that go for the gsr wing wires but you can just cover it up with tape or buy a plug for it.
Old Nov 1, 2009 | 08:23 AM
QuikSilverTeg's Avatar
Same here, I put one on my DC4 and it was direct bolt on and had to plug the extra hole for the brake light wiring.
Old Nov 1, 2009 | 10:47 AM
PaulMc's Avatar
Painfully Stupid
Does your car have a third brake light in the rear window? I realize you had a GSR spoilier on your car, so the light on there acted as your third light, but a lot of cars with spoiliers have the third light in the rear windshield and it just doesn't work until you wire it.
FYI the ITR spoilier doesn't have a brake light in it, If yours has one it isn't OEM.
Old Nov 2, 2009 | 11:36 AM
No one said anything about and ITR Wing with the 3rd brake light, just that the wire hole for the GSR wing light would have to be plugged.
Old Nov 2, 2009 | 03:16 PM
mouab18c1's Avatar
the guy is only saying that if the OP has a third break light with his ITR wing then it is not an OEM ITR wing...
hondatuner020
Jan 11, 2010 05:05 PM
njmad
Oct 26, 2009 02:32 PM
teg_dc2
Mar 13, 2008 02:38 PM
Mr.DC2TurBo
Aug 19, 2004 08:06 AM
slowacura
Dec 9, 2003 03:50 PM
