ls turbo clutch
ls turbo clutch
well i took my car to the track today and i was very disappointed. i only ran a 14.1 at 105 spinning until third. my clutch was slipping really bad so i am going to go ahead and replace it with a better one. but im not sure what to get i dont want to get another clutch and it slip aswell. what do you guys recommend? i was looking at some 6 puck clutchs but i dont know what brand is better than others. also would it be a worth while investment to throw a 12lb or 8lb flywheel in aswell.
Re: ls turbo clutch
Exedy or Competition Clutch are who I personally like. Both make good pieces. What is your setup and what kind of power are you putting down? That is what we really need to know to be able to direct you to the proper clutch.
Re: ls turbo clutch
I have the comp. clutch stage 5 in my car. It's actually more like a stage 4 according to inline pro where I bought it. 4 puck sprung hub with hd plate. I was worried about buying at first b/c I didnt want a super stiff clutch. Don't worry it's not much more than stock pressure. I'd say go with the stage 4 6 puck sprung hub.
Re: ls turbo clutch
car is tuned on 10lbs ls turbo ls tranny putting right at 300whp and im adding cams and a little more boost this dec. to try to make 350ish whp
Re: ls turbo clutch
act extreme and a 6 pucks it grabs very aggressive and awesome on the track... the only down fall is that it wears very quick cuz its so aggressive... the pedal pressure is as good as normal stack clutch will feel. If u have the extra money needed the you should go for the twin plate clutch that the big boys used.
