No Vtec?
Old Feb 21, 2002 | 04:28 PM
b20b's Avatar
New User
Default No Vtec?
Ok I posted a question earlier, I have a b20b Gsr head setup. Anyhow I tapped the turbo oil line off of the oil line from the block to the head. Everything is working fine except there is no Vtec. I'm thinking since Vtec is activated by oil pressure, maybe I'm losing Vtec because there is not enough oil pressure. Being that I broke off of the main oil line from the head. What do you guys think? Thanks.
Old Feb 21, 2002 | 10:03 PM
mugenracer's Avatar
Default Re: No Vtec? (b20b)
does sound like that theres not enough pressure to activate the vtec, is your engine check light on?? if not then the vtec solenoid is obviously activting correctly, so more than likely its the pressure.
Old Feb 21, 2002 | 10:50 PM
92TypeR's Avatar
FSAE
check the lines going into/out of the solenoid. If you can't find anything wrong from the outside, you most likely are loosing oil pressure from the turbo line. Also, what ecu are you using on the b20/vtec?...you could have a crapped out ecu...just another guess.
Old Feb 22, 2002 | 03:41 AM
b20b's Avatar
New User
Default Re: No Vtec? (92TypeR)
No there is no CEL. I was thinking that too. But no light. I'm using my p28 ecu chipped with Skunk2 program. I was originaly n/a. If it is the oil pressure being insufficient, where else could I tap to get oil for the turbo? Or is it possible to get another oil pump that would be capable of supplying enough pressure? I don't know. But I really miss my Vtec man! Thanks again for your help.
Old Feb 22, 2002 | 08:21 AM
92t3gra's Avatar
New User
Check your ecu wirings, make sure they are not loose.
Old Feb 22, 2002 | 02:14 PM
civicdragon's Avatar
Default Re: No Vtec? (92t3gra)
IS the Skunk2 chipped witht the knock sensor removed? If not then it might be because you dont have it installed...
Old Feb 23, 2002 | 04:08 AM
b20b's Avatar
New User
Default Re: No Vtec? (civicdragon)
Ecu wiring is ok. I had Vtec working before I turbo. Yeah the Skunk2 is chipped without knock sensor. I believe if the knock sensor is not installed, it will throw the CEL. Thanks again for everyones input.
Old Feb 23, 2002 | 08:39 AM
mattL's Avatar
for a while i thought i'd lost my Vtec, cause i coulnt hear it anymore but it was strange cause it still pulled hard till redline, it happened right after i switched from a short ram to a cold air. could maybe your new setup have changed the regular engine noise youre used to? or are you feeling the lack of power top end? cause if your vtec doesnt switch over you have nooooo power up top. if you think this is a stupid comment then just ignore me
Old Feb 23, 2002 | 11:20 AM
b20b's Avatar
New User
Default Re: No Vtec? (mattL)
Hahaha! Stupid comment?? No man, never a stupid comment when your trying to help. All comments appreciated. But along with the noise not coming in, the top end is dead. Loss of power. So definately know that the Vtec is not engaging. Thanks.
B18c1turboedEK
Jun 6, 2007 10:07 AM
EG Boostin
Feb 2, 2007 10:21 AM
b20b
Feb 22, 2002 03:46 AM
b20b
Feb 22, 2002 03:45 AM
b20b
Feb 22, 2002 03:42 AM
