distributor cap and rotor replacement
Old Feb 19, 2002 | 09:00 PM
bocian's Avatar
Default distributor cap and rotor replacement
is this one of those easy DIY jobs? or is there something that can be easily screwed up and cause a lot of problems.
im doing my tune up and this is one of the things that i want to replace
are there any sites that help go through this? i checked out the c-speedracing.com site how to section but they didnt have anything
thanks in advance
-tom
Old Feb 19, 2002 | 09:43 PM
Acura_I-RS's Avatar
Default Re: distributor cap and rotor replacement (bocian)
hey wasup? i would say just go and order the msd modified distributer cap its like 29.99, and then get an external msd coil, they are like 35 bucks, a lot nicer if u ask me and you can get a rotor, and all this stuff at carparts.com rotors are like 6-11 bucks
Old Feb 20, 2002 | 12:18 AM
integra0260's Avatar
New User
Default Re: distributor cap and rotor replacement (Acura_I-RS)
piece of cake.. heres how to do it.
1. Take off the cap, there are 3 screws holding it.
2. Look at the rotor with your head along the firewall facing the front bumper. Do you see the screw? If not, get in your car and crank the motor over just a click and get out and see if you can see the screw holding the rotor in place. Repeat this step until you locate the screw.
3. Remove rotor screw, (BE CAREFUL NOT TO DROP IT!)
4 take off rotor
5. Put new rotor in
6. Put screw back in to hold the rotor in place
7. Put the distributor cap back on
8. Tighten the cap back on with the 3 screws
9. Dont forget to put the spark plug wires back on the cap and dont forget the firing order.
10.
Old Feb 20, 2002 | 01:43 AM
LostGsr's Avatar
Becareful when taking the rotor screw off. Its very easy to strip it! It happen to me, so I needed to drill it out.
Old Feb 20, 2002 | 05:23 AM
StyleTEG's Avatar
Default Re: distributor cap and rotor replacement (LostGsr)
Yeah, its a pretty easy job. I did it in 10min with out any experiance.
Don't forget to replace the gasket that comes with it. I forgot to the first time and had to redo it to put the gasket on. The rotor screw is on there pretty tight like Lost GSR said, just make sure to use the right screwdriver.
Old Feb 20, 2002 | 07:14 AM
betsuni's Avatar
yes it is very easy to strip....try to do this when the engine is cold. when the engine is warm it is harder to remove the screw...i think it expands due to heat.
Old Feb 20, 2002 | 06:19 PM
bocian's Avatar
Default Re: distributor cap and rotor replacement (integra0260)
what do u exactly mean? how hard is it to get the firing order right?
Old Feb 20, 2002 | 06:50 PM
StyleTEG's Avatar
When you remove the old cap, don't unplug the wires. They need to go back in the exact same spaces on the new cap.
Once you have the new cap and rotor installed, replace the wires one by one in the exact same spot on the cap.
lmike6453
Feb 22, 2008 07:34 PM
218luder
Feb 7, 2008 08:39 PM
hotdoggies
Jan 27, 2006 12:08 AM
absolutgsr
May 28, 2002 11:53 PM
Mike P.
Aug 2, 2001 10:19 PM
