injectors
Old Feb 19, 2002 | 04:08 PM
ghettols's Avatar
Default injectors
has anybody upgraded their injectors??and those of you that have, do you reccomend this upgrade???
Old Feb 19, 2002 | 04:12 PM
Acura_I-RS's Avatar
Default Re: injectors (ghettols)
i was actually wondering the same thing, i have a 94 integra RS with intake exhaust, chipped ecu, modified cap and blaster ss external coil, and was wodnering first, what cc the stock rs injectors are, and which cc injectors would make a good upgrade, and would i need either an s-afc, or a fuel pressure regulator to control it, or will they be fine with out??
Old Feb 19, 2002 | 04:15 PM
ghettols's Avatar
Default Re: injectors (Acura_I-RS)
damn, nice # on that ls.
pyr huh? we used to go to his shop when he was in long beach...how's your ecu modified??
Old Feb 19, 2002 | 05:19 PM
Muglit's Avatar
New User
stock injectors: 240cc
Old Feb 21, 2002 | 12:07 PM
ghettols's Avatar
Default Re: injectors (Muglit)
so has anybody done this mod or what???
Old Feb 21, 2002 | 01:22 PM
Acura_I-RS's Avatar
yea, what he said, i wanna up grade my ls injectors, maybe to those prelude ones, but im not sure if they will work in an ls, and what size they are
Old Feb 21, 2002 | 02:21 PM
Muglit's Avatar
New User
Most saturated injectors will work on the 'teg. The '97+ prelude injectors are saturated I believe they are 280cc.
You should only upgrade your injectors if they cannot provide the flow rate needed with available pressure. You should first get a fpr to adjust the pressure and if you are still running lean after raising the pressure enough to put a strain on your fuel pump then you should get larger injectors so that the fuel pressure can be lowered. With the larger injectors you will probably need a fuel controller in combination with the fpr to better tune the fuel.
Old Feb 21, 2002 | 03:44 PM
ghettols's Avatar
thanx...
Old Feb 21, 2002 | 10:37 PM
Malice's Avatar
New User
i have the venom injectors. only reason i got them cause they were given to me. they flow 10% better than stock
jyracer
Nov 23, 2009 05:56 AM
MyFirstTuner
Aug 26, 2006 07:52 AM
Octoman
Jun 19, 2004 10:36 PM
Westrock2000
Apr 24, 2003 04:20 PM
SinisterTegLsJdmItrConv
May 31, 2002 06:52 PM
