vibrating dash
Old Feb 23, 2002 | 01:56 AM
Vic Nyce's Avatar
Default vibrating dash
ok i just bought a 94 GSR and when at idle, the car vibrates like its nobody's business. the dash makes so much noise. i tried to hold the dash and push it towards the firewall, but no dice. it was tight. the guy said he put stiffer motor mounts in it b4 i bought it. could that be the culprit? makes my Civic DX seem luxurious lol. once i rev past 2000 RPM however, its fine. the vibration is sort of like when ur in DRIVE in an automatic while holding the brake, then when u let go, its smooth. please help
[Modified by Vic Nyce, 10:58 AM 2/23/2002]
Old Feb 23, 2002 | 04:25 AM
95gsr's Avatar
Default Re: vibrating dash (Vic Nyce)
the guy said he put stiffer motor mounts in it b4 i bought it. could that be the culprit? once i rev past 2000 RPM however, its fine.
There you go i have 95 gsr energy susp. motor mount where put in about 1 month ago the vibrates only at idle AKA stopped at the light as soon as little gas is giving the vibration goes away.
Old Feb 23, 2002 | 12:50 PM
KanzenR95GSR's Avatar
i have a 95 gsr that i just got done rebuilding and i installed energy suspension motormount inserts and my car vibrates at idle and sometimes very low rpm. . . ive also wondered if the inserts could have been the culpret of all the vibration.
Chris Newman
Jan 18, 2013 12:26 AM
b16ej6
Oct 22, 2010 09:37 AM
eastbayrep
Dec 18, 2009 10:48 AM
chinochanginc
16
Apr 11, 2008 07:34 PM
