SQUEAKING NOISE
Old Feb 20, 2002 | 10:04 PM
PoWeRBaN_PaNdA's Avatar
Default SQUEAKING NOISE
I NEED HELP, WHENEVER IM DRIVING AND I COME ACROSS SOME UNEVENESS ON THE ROAD LIKE ON THE FREEWAY OR ON THE STREET MY FORNT END SQUEAKS, THIS ALSO HAPPENS WHEN I SIT IN THE CAR FOR THE FIRST TIME IS IT MY SPRINGS?
Old Feb 21, 2002 | 04:34 PM
Spyderwebab's Avatar
Default Re: SQUEAKING NOISE (notec_racer)
Mine does this too..Except in mine its REALLY bad...All four squeak...I believe its the Shocks, and I have better things to spend money on than this...But if you find out for sure...make sure you tell me what it costs to replace.
Old Feb 21, 2002 | 04:58 PM
SonicGSR's Avatar
Default Re: SQUEAKING NOISE (Spyderwebab)
Spyder:your camber kit (bushings) I have the same and this is common
spray em down with some silicon spray,try to avoid wd-40
from what I heard its bad for rubber
Old Feb 21, 2002 | 05:32 PM
Red98GSR's Avatar
New User
Default Re: SQUEAKING NOISE (SonicGSR)
DONT USE WD-40. Dont just avoid it DONT USE IT. It can eat bushings or something along those lines. Anyhow use white lithium grease on bushings.
Old Feb 21, 2002 | 06:21 PM
Prelussion's Avatar
Default Re: SQUEAKING NOISE (Red98GSR)
thw W in WD40 stands for water, but yes use the lithium grease, works grrrrrrrrrreat
Old Feb 21, 2002 | 07:46 PM
I bought the car already lowered with the SkunkWorks Coilovers, and when I was puttin on new tires and raising the car back up a little, the guys noticed duck tape, in the place of bushings(I Think in the place of bushings) he said they must have put them on there to keep it from rubbing or something...Any idea why they put duck tape around it, and if I need to do bushings, and about how much $ does that run...
Old Jun 28, 2005 | 09:44 AM
RCautoworks's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Red98GSR &raquo;</TD></TR><TR><TD CLASS="quote">DONT USE WD-40. Dont just avoid it DONT USE IT. It can eat bushings or something along those lines. Anyhow use white lithium grease on bushings.</TD></TR></TABLE>
Thats b.s, brought back from the dead just incase people read this and see that comment. wd49 does not eat at bushings
Old Jun 28, 2005 | 02:22 PM
DC2B18cya's Avatar
Default Re: SQUEAKING NOISE (90blackcrx)
OHH Noo I've used WD-40 on my bushings, when I installed my Ingalls camber kit Front and Rear. I hope it doesn't do anything bad to my bushings but hey it stop the squeaking noise for me though.
Old Jun 28, 2005 | 10:45 PM
Default Re: SQUEAKING NOISE (DC2B18cya)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC2B18cya &raquo;</TD></TR><TR><TD CLASS="quote"> OHH Noo I've used WD-40 on my bushings, when I installed my Ingalls camber kit Front and Rear. I hope it doesn't do anything bad to my bushings but hey it stop the squeaking noise for me though. </TD></TR></TABLE>
Are you joking or did you totally not read what I put
wd49 is basically water in a can
JDMPR
Nov 18, 2009 09:41 AM
imadigitalgod
Audio / Security / Video
10
Mar 1, 2009 09:00 PM
rEnZ94tEgGy
Suspension & Brakes
Apr 27, 2008 11:58 AM
Maverick77
Nov 26, 2002 12:06 AM
Immortal23
Sep 16, 2001 02:46 PM
