question?
Old Feb 19, 2002 | 09:38 AM
gsr stuie's Avatar
Default question?
Ok my gsr is blowin black at high rpms, normal oil consumption, even though oil would be blue in color. I have no idea what's causing this, but the car seems like it's lost it edge.
HELP
Old Feb 19, 2002 | 09:51 AM
gsr stuie's Avatar
Default Re: question? (gsr stuie)
ok i am not a newbie, so please give me some idea what to check. Come on guys, compression is fine, only have 60,000 miles.
Old Feb 19, 2002 | 10:01 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
I believe black is an indication of running rich. Is the ECU throwing any codes? You might want to check the O2 sensors, perhaps replace them.
Old Feb 19, 2002 | 10:08 AM
gsr stuie's Avatar
Default Re: question? (PatrickGSR94)
no codes, running a comptech ecu and the car has been fine for two years, but i use octane boost at the track and run the car hard (lapping). I was thinking o2 sensors too, but car sometimes pulls sometimes it feels like it's straining. The plugs had slight carbon deposits on them, which is what really surprises me as i am not easy on the car.
Old Feb 19, 2002 | 10:18 AM
KraZyCHOWMEIN's Avatar
are u sure the oil consumption is normal, mine is getting a lot of blow by also due to high mileage and bad piston rings, it could also be ur valve seals leaking oil into the combustion chamber creating the smoke at high RPM's.......
ProjectEvilEj2
Mar 1, 2013 06:28 AM
k20chornicalz
15
Dec 19, 2008 04:34 PM
92integraVTECgsr
Jan 12, 2008 09:14 AM
georgekobe8
Jan 31, 2006 09:43 AM
Flamenco-T
Nov 23, 2001 09:38 AM
