CEL Code 10, IAT
Old Feb 18, 2002 | 04:06 PM
Red2001GSR's Avatar
New User
Default CEL Code 10, IAT
Okay, here's the story.
I had taken my airbox lid off to see what it sounded like without it.
I decided I didn't like the idea of sucking in hot engine air, so I put the lid back on.
When I started the car back up, I had CEL 10. Does anyone know where I can find the IAT sensor? What should I be looking for?
I'm clueless, any help would be appreciated.
Old Feb 18, 2002 | 07:26 PM
Red2001GSR's Avatar
New User
Default Re: CEL Code 10, IAT (Red2001GSR)
ttt
Old Feb 18, 2002 | 08:00 PM
IN VTEC's Avatar
IAT sensor is on the manifold, either on the top to the right or on the back...somewhere about there.
First thing to do is reset the ECU by removing the 7.5A backup fuse from the fusebox by the battery. Then, check to see if the same DTC re-occurs.
It's probably just a random code from the heat soak after driving with the lid off for a while. Just my guess.
Old Feb 19, 2002 | 02:36 AM
HKxBlur's Avatar
Default Re: CEL Code 10, IAT (IN VTEC)
Unless u actually broke the IAT sensor or wiring, which is nowhere near the intake tubing, it's definitely this..
The sensor on my obd2 gsr is on the upper-rear-left side of the intake manifold.. On the LS it's in the middle right behind the injectors..
2001dxtn
Honda Civic (2001 - 2005)
May 22, 2012 10:46 PM
jetblack
May 16, 2006 06:20 PM
98JDM_Type_R
Sep 1, 2004 08:12 PM
mixmastabob
Aug 20, 2004 07:29 PM
N1NjA TuRtLE
12
Jun 5, 2004 08:30 PM
