Maintenance
Old Apr 2, 2002 | 01:35 AM
StinkyTofu's Avatar
Default Maintenance
I'm going to be putting high lift cams and high compression pistons in my gsr. I was wondering what I should be checking every now and then? Paper on the box says that these cams will put more wear on the valvetrain/engine. When should i be changing timing belt etc? thanks in advance.
Old Apr 2, 2002 | 02:56 AM
harryg's Avatar
Default Re: Maintenance (StinkyTofu)
While you're in there, do the timing belt, water pump, and tensioner. You're supposed to do 'em every 70k miles.. but trust me, GET IT OVER WITH. It's a 300+ job if you take it somewhere. Not to mention it's a 1000+ job if your timing belt snaps due to not changing it earlier. Good luck.
Joebilious
Jun 28, 2018 11:20 AM
ezol
Acura TL, RL & ZDX
11
Sep 21, 2010 08:29 AM
Ramma
May 15, 2008 07:34 PM
ricebowl
Mar 3, 2006 07:41 PM
nadc2
May 21, 2003 11:50 PM
