Check engine light
Old Apr 3, 2002 | 04:39 AM
ex_crxer's Avatar
Default Check engine light
I noticed after starting my 1995 integra yesterday that the Check engine light came on and stayed on until I started the car again (while resetting the light). The engine was warm when the light showed up. Anyway, Since i've cleared it, the light has not re-appeared. Is this something I should worry about?
Is there a LED somewhere (like on the CRX ECU) that can give me a indication?
Thanks
Marc
1995 Integra
Old Apr 3, 2002 | 05:31 AM
PM-Performance's Avatar
Default Re: Check engine light (ex_crxer)
yes , flip up the carpet and look at the ecu . it will have a little glass window with an led in it and check the flashed.
Old Apr 5, 2002 | 06:17 AM
ex_crxer's Avatar
Default Re: Check engine light (itr206)
Thanks for the tip, I will have a look. Although I imagine that the code disappears when the 'check engine light' is reset?
Thanks,
Old Apr 5, 2002 | 06:44 AM
Rainmaker's Avatar
Really? I didn't know that. I thought you had to jump the service connector and then read the flashing from the check engine light itself.
Hmmm.
Old Apr 5, 2002 | 07:20 AM
Eva01's Avatar
Yeah for the 94 and up integra, there is no led to read. You must jump the connector that is located under the dash and then the CEL will flash in code. Long flashes are worth 10 and short flashes are for 1. This will give you a number that will correspond to the specific reason why the CEL is flashing. Check out this link for a better explanation.
http://www.team-integra.net/sections...p?ArticleID=34
Old Apr 5, 2002 | 07:21 AM
Default Re: Check engine light (Eva01)
my bad, i saw the crx thing and didnt readit close enough, i thought you had a crx ecu
i thought that looked funny .
sorry
Old Apr 6, 2002 | 07:54 AM
ex_crxer's Avatar
Hi Eva1,
Do you happen to have the html document for this page? as the URL requires a member logon to get to the ecu document.
Thanks
TeamSumner
Sep 29, 2014 05:14 AM
aspire
Jun 28, 2010 10:49 AM
89civichb
May 10, 2007 06:42 PM
keprunited8
Jan 30, 2005 01:40 PM
VTECVillain
Jan 6, 2002 11:40 AM
