Installing Guages
Old Apr 1, 2002 | 01:37 PM
WNT KCH's Avatar
Default Installing Guages
I need helping installing my A/F guage and fuel pressure guage
For the A/F guage what color wire do i hook it up to and where in the engine bay is it? (I thought i once read it was a white wire w/ a green stripe but I want to double check.
And for the Fuel Pressure guage how exactly do I hook up the sender?
TIA
Old Apr 1, 2002 | 07:42 PM
TomO's Avatar
Default Re: Installing Guages (WNT KCH)
I can help with the A/F gauge...it should be a white or white w/black stripe on the comupter harness I think harness D14, it's easy to find only wire like it.
Tom O
Old Apr 1, 2002 | 08:19 PM
Westrock2000's Avatar
Default Re: Installing Guages (SonicGSR98)
Just did this actually. I spliced into the white wire coming off the first O2 sensor (on header). If you do that though try to do it on the harness side and not the sensor side. That way you can replace the O2 sensor someday if needed and not have to resplice again. Oh by harness side I mean, the O2 sensor has a harness which plugs into another harness
<car>--------[]-------<O2 sensor>
.............|.....L> harness
.............L> where you splice
I used one of those push clamp things with the metal bar that goes into both wires, just make sure the wires are thick enough to get cut by the metal tab as my power one was not and it didn't work at first
[Modified by Westrock2000, 11:19 PM 4/1/2002]
Old Apr 1, 2002 | 09:45 PM
Malice's Avatar
New User
if ur gonna wire it from the harness in front of the battery, it is the white wire with the red pinstripe
Old Apr 2, 2002 | 05:55 PM
WNT KCH's Avatar
Default Re: Installing Guages (MaliceGSR)
thanks for the help w/ the A/F now does anyone know how to hlep me hook up my autometer electronic fuel pressure guage?
Old Apr 9, 2002 | 08:38 AM
WNT KCH's Avatar
I see 2 white wires with red pin striping which one is it?
turbotime
Dec 6, 2006 06:40 AM
_gurusan_
Aug 2, 2006 05:59 PM
k7q
Mar 9, 2006 09:45 PM
1SlowSi
Feb 14, 2005 05:14 AM
ChrisDaun
Feb 12, 2004 04:04 PM
