Need Some help!
Old Apr 5, 2002 | 03:55 PM
.paul's Avatar
Default Need Some help!
gurlfriends car doesnt start... it just clicks ....im assuming it's the starter.. she has a LS integra 94.... can you all tell me anything to look for like of what could be the problem.. i know for sure its not the battery ;p
thanks for your help in advance it is modified.. if that would make any difference I/H/E etc. etc.
[Modified by h00kup, 12:55 AM 4/6/2002]
Old Apr 5, 2002 | 04:02 PM
94LSTEG's Avatar
New User
Default Re: Need Some help! (h00kup)
I had the same problem. It lasted for a couple of months. I thought it was the battery so I had it changed. It would come and go. It never made the noise when I brung it to the mechanic but in the end it turned out to be the starter.
Old Apr 5, 2002 | 04:13 PM
poison's Avatar
it's just clicking? that would be the starter then,
take off the starter but have it hooked up, and try to start it, and see if the lil spindle spins in the starter. if it doesn't, need a new starter, if it does, then it should be turning the fly wheel. if not turning the flywheel, might be faulty starter, if that's not it, then ur flywheel might have bad teeth and you need to bring it to the dentist ;x (get a new one )
edit - DAMNIT my mom's del sol (d16z6) is havin same probs
only we had starter checked and was fine, the battery is also good.
any suggestions??
[Modified by poison, 11:52 PM 4/5/2002]
Old Apr 6, 2002 | 11:25 AM
.paul's Avatar
Default Re: Need Some help! (poison)
thanks guys!
96_LS
Nov 29, 2006 10:00 AM
oneforce
16
Jun 22, 2006 08:19 AM
Touge Tuning
May 3, 2006 11:14 AM
HXvtec
Nov 6, 2004 02:15 PM
lilcasino
Jun 26, 2002 07:21 PM
