Removing Harmonic Balancer
Old Apr 4, 2002 | 08:12 AM
Integra91LS's Avatar
Default Removing Harmonic Balancer
Ok the engine is out and it is on a stand. We tried to remove the harmonic balancer but that pully is not stable nor can we get it too the point where the nut in the middle of it will beak loose. We need to remove it in order to redo the timing. Any suggestions?
Old Apr 4, 2002 | 08:26 AM
slowerthanu's Avatar
New User
Default Re: Removing Harmonic Balancer (Integra91LS)
You need a special tool to do it correctly I believe, atleast thats how I have always done it.
Old Apr 4, 2002 | 08:32 AM
Default Re: Removing Harmonic Balancer (slowerthanu)
I have the tool, when we try to remove the nut, the pully turns. How can we keep that from turning?
Old Apr 4, 2002 | 10:47 AM
Jackson's Avatar
you need a special tool or somehow ghetto lock the flywheel to keep the motor from turning while you try to break the bolt loose. 19mm is not a special tool.
Old Apr 4, 2002 | 10:59 AM
BlowOff's Avatar
New User
Default Re: Removing Harmonic Balancer (Jackson)
Stick a big *** screwdriver in one of the flywheel teeth and hope it doesn't pop out
Old Apr 4, 2002 | 11:48 AM
RedTeg95's Avatar
Default Re: Removing Harmonic Balancer (BlowOff)
When I removed mine I had to use an impact rench.
92EGMINIME
33
Feb 8, 2009 12:00 PM
tegmaniac
Aug 18, 2006 08:13 AM
imsagtrx7
Jul 5, 2004 08:54 PM
VWkila
17
Mar 31, 2004 05:53 PM
Akira-R
Jul 29, 2001 12:00 PM
