Camber kit
Old Apr 3, 2002 | 09:59 AM
GsrSedan's Avatar
Default Camber kit
Alright, let me say first that I did a search and learned a little, but I just want to know from you guys... which camber kit? All I really see are Ingalls, Progress, and Skunk2 (just front). I'm getting some ugly tire wear, and I'd like to be able to adjust for street/track changes. Thanks.
Old Apr 3, 2002 | 10:26 AM
GsrSedan's Avatar
Default Re: Camber kit (GsrSedan)
Ok, just found complete 4wheel Ingalls kit for 220. Gonna jump on that. It's at ARD, by the way.
Old Apr 3, 2002 | 10:29 AM
Fooser's Avatar
Well everytime you adjust your heights your suppost to get an alignment cause you screw the toe up. But as for Camber kits just make sure its easy to adjust cause the alignment shops will charge more if not. I have ignalls on mine and all you have to do is loosen the bolt to the bottom of it and slide the control arm in and out. then tighten when the camber is correct.
I'm pretty sure specialty products is a good brand to. it has the adjuster pin on the side so you just rotate it to adjust camber.
Usually uneven tire wear on say the inside is due more to the toe of your car. Bad camber will give you bad grip to the ground as well. So set your height and get an alignment. Trust me it was a $400 expense I should not have had soo soon because I didnt get the alignment after adjusting my height over and over. Usually if you work out a deal with the alignment shop they will give you a 6 month warranty or something so you can come back in whenever you think your alignment is off.
[Modified by Fooser, 7:32 PM 4/3/2002]
Old Apr 3, 2002 | 10:46 AM
GsrSedan's Avatar
Default Re: Camber kit (Fooser)
Yeah, from what I understand, Ingalls makes a great kit. I have unlimited access to a lift and a brand new Hunter alignment machine, so I'm lucky. My front and rear toe were fine, but camber was about -2.5 in front and about -1.8 in the rear. Great for autocrossing, but not for tire wear. The insides of all four are getting bad. Tires are too expensive to run for only 12k miles (Yoko Paradas).
Old Apr 3, 2002 | 11:03 AM
B18C-EJ1
Guest
Posts: n/a
Don't forget to GRIND the upper control arm before you put the ingalls camber kit in.
Here's my setup. Skunk2 front replacement arms - $225 Washers and bolts from Home Depot - $1.29 (rear)
Old Apr 3, 2002 | 11:14 AM
Fooser's Avatar
Default Re: Camber kit (B18C-EJ1)
Why do you need to gring the upper control arm?
Old Apr 5, 2002 | 08:03 PM
GsrSedan's Avatar
Yeah, what do you mean by grind??
Old Apr 6, 2002 | 08:15 PM
B18C-EJ1
Guest
Posts: n/a
The end of it has to be ground down because if you don't it'll hit the outside edge of the frame in the wheel well.
KDvtec5757
Dec 8, 2008 07:47 PM
inspector01
Suspension & Brakes
13
Jun 27, 2008 04:12 PM
hatch96y7
Oct 13, 2007 09:27 AM
itsJDMyo
13
Jan 7, 2005 10:40 AM
Anderson
Jun 18, 2002 01:06 PM
