is a b18c1 an interference motor, need help quick
Old Mar 14, 2003 | 04:05 PM
shockincivic's Avatar
Default is a b18c1 an interference motor, need help quick
my gf just snaped her timing belt. i need to know if the b18c1 is an interference motor. or if some one can tell me a way to check a honda motor for bent valves with no timing belt it would be a big help
Old Mar 14, 2003 | 04:12 PM
94TealGSR's Avatar
Default Re: is a b18c1 an interference motor, need help quick (shockincivic)
Yeah, definatley an interference motor. Snapped timing belt usually means bent valves. Good Luck.
Old Mar 14, 2003 | 04:13 PM
Default Re: is a b18c1 an interference motor, need help quick (94TealGSR)
thanks alot. off to pull a head
Old Mar 14, 2003 | 06:38 PM
Rtzx9r's Avatar
GDD 1%
depends on how she was driving when it broke. I have seen a few hondas snap belts and no damage at all. Pull the head anyways.
Old Mar 14, 2003 | 08:41 PM
blackZC (W)
Guest
Posts: n/a
Default Re: is a b18c1 an interference motor, need help quick (Rtzx9r)
its all a matter of luck...i was racing on the freeway in my civic DX years ago..i had it reved out all the way in 3rd gear,it bounced off the rev limit..and sanpped..i was like OMG the engine is toast...got it home ,put on a timing belt and it fired right up.
Old Mar 14, 2003 | 09:22 PM
b19coupe's Avatar
Default Re: is a b18c1 an interference motor, need help quick (blackZC)
Civic DX (D15) is not an interference motor.
GSR is definately an interference motor. Unless you are extremely lucky, broken t-belt = bent valves.
Old Mar 15, 2003 | 11:14 AM
XDEep's Avatar
Default Re: is a b18c1 an interference motor, need help quick (b19coupe)
so why did they design it like that?
Old Mar 17, 2003 | 04:41 AM
JimBlake's Avatar
Default Re: is a b18c1 an interference motor, need help quick (XDEep)
To allow the valves open a bit wider for better flow; while having a higher compression ratio.
Old Mar 23, 2003 | 05:33 PM
B U N M A N G O's Avatar
sorry to bring this thread back from the dead, but from http://www.batauto.com/tbelt/hondatb.shtml, it says that the D15 is an interference motor...
Old Mar 23, 2003 | 06:25 PM
b19coupe's Avatar
Default Re: is a b18c1 an interference motor, need help quick (bunmango)
I have done several D15 timing belts that had shredded timing belt teeth. Not one of them bent valves. I have had to repair heads on GSR's and Type-R's that had only misshifted, not even broken a timing belt. If the D15 is an interference motor, it is only by a very small margin.
Old Mar 23, 2003 | 08:37 PM
natesgarage's Avatar
what does interferece motor mean? Thanks
Old Mar 23, 2003 | 09:17 PM
XDEep's Avatar
Default Re: is a b18c1 an interference motor, need help quick (nate007is)
the valves can touch the piston in the event of a timing belt snap or just bad ignition timing. non-interference motors like the toyota camry cannot suffer such a fate in which case you dont have to have a heart attack when the belt snaps.
DaX
10
Aug 11, 2016 09:33 AM
97DGreenEx
Jul 13, 2005 07:29 AM
C8V6C
Aug 16, 2004 11:22 AM
TurboBumblBee
May 24, 2003 08:12 AM
LL
Oct 15, 2001 04:40 PM
