G2 Revving Problem?
Old Mar 13, 2003 | 02:30 PM
AkumaMax's Avatar
Default G2 Revving Problem?
Hi I had recently just purchased a 1990 Acura Integra LS and when I started the car it starts revving itself like when you start it just starts revving from 1,000 to 3,000rpm I was wondering what could be wrong can someone plz help me.
Thanx in advanced. Matt
Old Mar 13, 2003 | 10:39 PM
AkumaMax's Avatar
Default Re: G2 Revving Problem? (AkumaMax)
Bump
Old Mar 13, 2003 | 10:41 PM
romeo619romeo's Avatar
idle sensor..check for vacuums leaks and check your radiator fluid
Old Mar 14, 2003 | 04:22 AM
CivicRacer90's Avatar
Could be many things. Here are what you should check for.....
1. IAC (Idle Air Control)
2. Check for any Vacuum Leaks
3. Intake Manifold gasket could have a leak which could cause a vacuum leak.
Most likely it's a Vacuum leak so check every single vacuum line to make sure you don't have a leak anywhere.
Old Mar 14, 2003 | 08:43 AM
junya16's Avatar
Default Re: G2 Revving Problem? (CivicRacer90)
yea check your idle control cause that just happened to my car not too long ago and that was the problem
honcrf150
13
May 29, 2012 10:28 AM
blackEGFTW!
10
Apr 13, 2009 01:08 PM
BOOSTED_JDM_DB8
Feb 3, 2006 01:01 AM
mrnicolas
Oct 31, 2002 02:13 AM
Turbo Powa
Oct 7, 2002 11:58 AM
