abs code 81 & 16
I'm getting abs code 81, and 16 when i check for codes. I don't have my helms manual so i can't check to see what the codes are. Anyone have any insite into this? Maybe how to fix it?
as per helms.... so other ppl can read this later if they need
81
Symptom: ABS function
Probable cause: Wheel sensor signal dissappears at speeds of 6mph or less, or faulty ABS control unit
Probable cause when symptom does not reappear: intermittent interruption in the wheel sensor, or Rough road driving ( no problem)
Test drive the car at speeds of 12mph or more for more than 2 min, if you still throwing the code, chekc for a loose wheel sensor. If still throwing code you need to replace the ABS control unit.
81
