a/c problems
Old Jun 26, 2003 | 08:12 PM
AH Tow EX's Avatar
Default a/c problems
if i'm on the freeway and i have my a/c on, it's fine, but once i get off and in neutral, it starts making a buzzing sound. well, more like a vibrating sound, what could be the problem? TIA everyone
Old Jun 26, 2003 | 08:18 PM
ciRcuitJerk's Avatar
jus f0 dekarayshunZ
Default Re: a/c problems (AH Tow Ex)
do you feel a difference in the "cooling" power
Old Jun 26, 2003 | 08:46 PM
AH Tow EX's Avatar
Default Re: a/c problems (ciRcuit_ _ _)
not really, but on really hot days, i get scared, and i turn it off. my temp gauge goes up, but i don't really call that accurate...
Old Jun 26, 2003 | 09:33 PM
jonoknut's Avatar
are you sure the buzzing sounds isnt you ABS?
Old Jun 26, 2003 | 09:51 PM
AH Tow EX's Avatar
Default Re: a/c problems (jonoknut)
almost positive, it only makes that sound when i have the a/c on, and i'm not moving fast.
Old Jun 27, 2003 | 06:05 AM
JimBlake's Avatar
Open the hood & check around. Maybe it makes the noise even when you're driving faster but other noises cover it up? Couple things I can think of...
AC compressor belt is doing more work when the AC it on. Maybe its loose & humming a bit? Loose bracket holding the compressor? Bad bearing in the idler pulley for the AC belt?
Radiator fans run when you switch the AC on. Maybe one's not balanced real good or its rubbing on its shroud?
Old Jun 27, 2003 | 06:30 AM
romeo619romeo's Avatar
Default Re: a/c problems (JimBlake)
you have too much freon in your system.. release some of it till it fixes it.. release it from the high side...the outsde heat.. raises the pressure inside the lines and makes the compressor shut down and makes that awful noise.. im pretty sure the sound is.. breh.. kinna sound am i correct...
Old Jun 27, 2003 | 10:18 PM
AH Tow EX's Avatar
Default Re: a/c problems (romeo619romeo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by romeo619romeo &raquo;</TD></TR><TR><TD CLASS="quote">you have too much freon in your system.. release some of it till it fixes it.. release it from the high side...</TD></TR></TABLE>
how would you do that?
Old Jun 28, 2003 | 11:20 PM
AH Tow EX's Avatar
okay, so i drove it around today with the a/c on for most the day, and the same problem, it sounds like my whole car is vibrating when i'm at a stop. please advise
Old Jun 30, 2003 | 05:38 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AH Tow Ex &raquo;</TD></TR><TR><TD CLASS="quote">how would you do that?</TD></TR></TABLE>
You should take it somewhere that recovers refrigerant instead of just releasing it.
But you might want to measure pressures to make sure that it really is overfilled.
Old Jun 30, 2003 | 09:07 AM
on the driverside theres a little **** near the headlights with a blue cap that ses H on it.. open it and stick a small little screw driver in it.. if you push to hard it will blast a grip of freon out.. just ever so gently do it
since you in san diego i can do it for you .. its no biggy im pretty sure you can do it yourself tho
Old Jun 30, 2003 | 08:39 PM
AH Tow EX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by romeo619romeo &raquo;</TD></TR><TR><TD CLASS="quote">on the driverside theres a little **** near the headlights with a blue cap that ses H on it.. open it and stick a small little screw driver in it.. if you push to hard it will blast a grip of freon out.. just ever so gently do it
since you in san diego i can do it for you .. its no biggy im pretty sure you can do it yourself tho</TD></TR></TABLE>
cool man, wha part of sd do you live? i live in PH
jd101
Honda Civic (2001 - 2005)
May 14, 2015 04:36 AM
wickedmaniac
12
Jun 6, 2014 08:18 AM
hillbillycivic
10
Mar 3, 2013 09:02 AM
P-DuBB
23
Aug 8, 2005 10:36 PM
THE94GSR
Oct 29, 2003 10:35 AM
