transmission changes Help.
Old Jun 25, 2003 | 08:51 PM
SkyLinER's Avatar
Default transmission changes Help.
I have a B18B1 for my integra, and it's automatic. I am wondering if it is possible to change to manual. If possible, what do I need to buy to shift it over to manual transmission.
Old Jun 25, 2003 | 08:54 PM
xteg95's Avatar
Default Re: transmission changes Help. (SkyLinER)
its very possible, i dont know all the exact details but i would first try search for auto to manual trans or something first, you'll find plenty of threads.
Old Jun 25, 2003 | 10:38 PM
shamoo's Avatar
Will you make something up for me please?
Default Re: transmission changes Help. (xteg01)
Yes it is possible. I have done it to my old 97LS Integra.
Basically my suggestion is.....If you have a shop hookup with labor [/b]OR[/b] you can do it yourself, then go ahead and do the swap. If you don't have any of these, don't bother because they will charge you nearly $3K to do it...at least.
Barebones you'l need:
1) B-series tranny
2) Clutch/flywheel
3) Master/slave cylinder
4) Shift linkages
5) Starter from 5-speed Integra
6) Driver's side axle
7) Intermediary shaft
8) Assorted hoses, nuts, and bolts
EDIT: Clutch pedal assembly too (brake not totally necessary). Thanks JimBlake
Stuff you don't need, but is good to have to make everything perfect:
1) Center console from 5-speed Integra
2) ECU from 5-speed B18B1
There is more stuff, but it's kinda late. Everything is pretty easy except for the wiring. That's a bit difficult.
Modified by shamoo at 12:58 PM 6/26/2003
Old Jun 26, 2003 | 05:33 AM
JimBlake's Avatar
Default Re: transmission changes Help. (shamoo)
You probably should get a clutch pedal, too.
I figured you knew that.
Also, with an auto, theres a starter interlock switch on the shifter. For a manual, the interlock is on the clutch pedal. So you have to run some wires around...
Modified by JimBlake at 1:40 PM 6/26/2003
Modified by JimBlake at 1:41 PM 6/26/2003
Old Jun 26, 2003 | 08:21 AM
PLRacer's Avatar
im gonna be converting my auto to 5 speed soon too.
jdmb20boi
May 30, 2008 10:17 AM
ekslammed
Jun 19, 2007 10:19 AM
Jdmon079
Dec 29, 2006 12:56 PM
ahmad-a
Dec 2, 2006 09:16 AM
thecolombian
Jan 15, 2006 11:59 AM
