engine mount installation
Old Jun 29, 2003 | 12:57 AM
216.226.142.95:27016's Avatar
Default engine mount installation
im trying to put the driver side engine mount bolt back on, the long one that goes horizontally, but im having trouble sliding it all the way in. it will pass though the first hole, the engine mount itself but it gets stuck on entering the last hole in the chassis. anyone know how i can align the holes straight?
Old Jun 29, 2003 | 01:04 AM
MaxSterling's Avatar
Default Re: engine mount installation (216.226.142.95:27016)
jack up entire engine using jack and 2x4 wood. and loose the 3 mount bolts, slide in bolt , set mount so holes line up, and bolt it up.
Old Jun 29, 2003 | 01:12 AM
P1mpSlap's Avatar
Default Re: engine mount installation (keith_phan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by keith_phan &raquo;</TD></TR><TR><TD CLASS="quote">jack up entire engine using jack and 2x4 wood. and loose the 3 mount bolts, slide in bolt , set mount so holes line up, and bolt it up.</TD></TR></TABLE>
also use a pry bar to align the bolts so you can guide them in.
Old Jun 29, 2003 | 02:27 PM
Default Re: engine mount installation (P1mpSlap)
cool ill try jacking up the engine and if that doesnt work ill be back with more questions
96_coupe
Aug 18, 2012 09:03 AM
Crimson_Tide
Jul 20, 2005 07:40 AM
GapxGuy
Welding / Fabrication
Aug 25, 2004 07:39 AM
david90
Aug 15, 2003 03:24 PM
RSVTECDC4
Jul 16, 2003 04:22 PM
