Failed Smog, Please help.
Old Jun 24, 2003 | 05:31 PM
asianautica's Avatar
Default Failed Smog, Please help.
Hi all, thanks in advance for all your help. I just did a pre-test today and it failed. Here's the result:
15 mph: HC Max = 90 - Measure = 278
CO Max = 0.54 - Measure = 3.51
25 mph: HC Max = 56 - Mearure = 172
CO Max = 0.53 - Measure = 1.62
I have intake, headers, Skunk2 Stage 1 Cams, and Hondata S100. What do you think I should do to fix this problem? Would leaning out the fuel fix this problem? Any help would be great. Thanks again.
Old Jun 24, 2003 | 06:52 PM
sPaRk'iT's Avatar
Default Re: Failed Smog, Please help. (asianautica)
go back to completely stock and you only need one header, which is gonna be stock too.
Old Jun 24, 2003 | 06:57 PM
redacura's Avatar
Default Re: Failed Smog, Please help. (sPaRk'iT)
what type of header u got?
Old Jun 24, 2003 | 07:30 PM
MugenGTR's Avatar
Default Re: Failed Smog, Please help. (redacura)
try plugging in your stock ecu and smogging it w/ that, that should help.
Old Jun 24, 2003 | 08:04 PM
seanb18c1's Avatar
I have a similar set up and I have to get my emmission testing done this year.
The Plan: Put my stock ECU, header, cat, exaust, use race gas, and get my cat super hot right before testing.
Old Jun 24, 2003 | 08:11 PM
StinkyTofu's Avatar
Default Re: (seanb18c1)
Its your hondata. Most likely your program runs very rich. I think thats the answer to your problem. Either that or you're running a test pipe or something. Maybe change your cam gear settings back to 0,0. Skunk2 stage 1 cams are supposedly smog legal, so there shouldn't be a need to switch back to stock. To me, being able to pass smog would be the only reason to get the stage 1's.
Old Jun 24, 2003 | 10:26 PM
Default Re: (StinkyTofu)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StinkyTofu &raquo;</TD></TR><TR><TD CLASS="quote">Its your hondata. Most likely your program runs very rich. I think thats the answer to your problem. Either that or you're running a test pipe or something. Maybe change your cam gear settings back to 0,0. Skunk2 stage 1 cams are supposedly smog legal, so there shouldn't be a need to switch back to stock. To me, being able to pass smog would be the only reason to get the stage 1's. </TD></TR></TABLE>
Yeah, I think it's the Hondata too. I'll get it reprogram soon. I'm not running any test pipe. I have stock cat and stock exhaust. I'll prolly set the cams back to 0,0 too. Do you think that'll help too? Skunk2 Stage 1's smog legalness is the main reason why I got it. Thanks for the suggestions. Anyone got any connections?
Old Jun 24, 2003 | 10:27 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redacura &raquo;</TD></TR><TR><TD CLASS="quote">what type of header u got?</TD></TR></TABLE>
I have DC 4-2-1 Header and AEM CAI. Both have CARB # so both should pass w/ no problem.
denisq6
Honda Civic (2006 - 2015)
Apr 21, 2012 08:13 AM
katanamast279
Aug 6, 2009 06:55 AM
D16z6BoostedEK
Apr 18, 2006 11:42 PM
JustAnotherHonda
Mar 8, 2003 02:31 PM
Ef Whore
Nov 24, 2002 01:23 PM
