B18C1 Crankshaft question
Re: B18C1 Crankshaft question (iiilgsrlll)
I think sometime ('96?) they went to a crankshaft sensor for the spark timing. It's behind the timing sprocket. Maybe they had to do something to the crank to make room for that?
Re: B18C1 Crankshaft question (JimBlake)
The CKF sensor by the crank/timing belt drive gear is a crankshaft speed fluxuation sensor. It helps to determine if cylinders are misfiring. It's not used for fuel or ignition timing. That stuff is still left up to the CKP and CYP sensors in the distributor.
The only difference b/w the crank assy on that side is the timing belt drive gear and a slight difference in the keyway placement.
OBD-I models have the keyway machined into the inside of the timing belt drive gear. You only need to make sure that the keyway is facing away from the front of the motor.
OBD-II models used a gear with extra teeth for the CKF sensor and required one keyway.
Re: B18C1 Crankshaft question (IN VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IN VTEC »</TD></TR><TR><TD CLASS="quote">The CKF sensor by the crank/timing belt drive gear is a crankshaft speed fluxuation sensor. It helps to determine if cylinders are misfiring. It's not used for fuel or ignition timing. That stuff is still left up to the CKP and CYP sensors in the distributor.</TD></TR></TABLE>
OK that makes sense. I don't have that, I just figured the CKF sensor would take up space or need its own keyway or something.
j4s0n1337
02-15-2012 03:07 PM
civhatch90
14
09-03-2006 10:28 AM
