front jacking point
Old Jun 29, 2003 | 12:12 AM
Loveless's Avatar
Default front jacking point
see this?
where did the jack up the car?
and where did they rest the car on? I searched and found someone say it's ok to rest it on front sway bar, can someone confirm this?
Old Jun 29, 2003 | 12:51 AM
Aaron M's Avatar
Default Re: front jacking point (Loveless)
place the jack stands on the side jack points, directly behind the front wheels, you'll see a spot where they rest on
Old Jun 29, 2003 | 12:53 AM
P1mpSlap's Avatar
In that picture, I think he has the stands on the front tow hooks, and the actual jack on the core support (not recommended!!).
Old Jun 29, 2003 | 01:10 AM
thaiphob's Avatar
Nikon!!!
just looking at the car shows you something is wrong with the owner. but yah, i wouldnt jack it up that way.
Old Jun 29, 2003 | 01:18 AM
Loveless's Avatar
Default Re: front jacking point (thaiphob)
yah? I got tired of having to jack each side up on the tow hools, kind of lazy to do that. Today when I jacked the car up it leaned to the side (a little) I was jacking up, I thought that was dangerous. my hand brake was in place.
Well that's fine I guess.
Old Jun 29, 2003 | 02:52 AM
dLo GSR-stolen-now-WRX's Avatar
From: kyoto sangyo daigaku, kyoto, japan, sometimes bay area CA
you can use the LCAs too
Old Jun 29, 2003 | 03:53 AM
HiRevn's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thaiphob &raquo;</TD></TR><TR><TD CLASS="quote">just looking at the car shows you something is wrong with the owner. </TD></TR></TABLE>
That's messed up man.
If you look under the front of the car, in the middle, there's a spot on the slashguard that has an arrow on it. That's where you could place the jack.
Old Jun 29, 2003 | 05:26 AM
theman-dlh's Avatar
Default Re: front jacking point (HiRevn)
ad .orig.jpg to the end for larger pic.
Old Jun 29, 2003 | 08:07 AM
spd18's Avatar
Default Re: front jacking point (theman-dlh)
he jacked the car up on the front radiator support in that picture. you can either jack up the front of your car there, or on the front tow hooks (one on each side). i would only put jack stands where it says to put them (picture shows in the post above) on the sides of the car, though.
Old Jun 29, 2003 | 08:21 AM
tony4311's Avatar
Default Re: front jacking point (spd18)
just look under the front of the car. There's a big metal bulge. Pretty easy to find if you just stick your head under there.
Old Jun 29, 2003 | 03:35 PM
.RJ's Avatar
.RJ
gawd... if youd' bother to go outside and look at your goddamn car you'd see hte jacking point. It is *not* on the core support (not to mention it would bend under the weight of the car) and they're not called "tow hooks" under the doors, its a jack(ing) point.
Old Jun 29, 2003 | 03:56 PM
96dc2's Avatar
Default Re: (P1mpSlap)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by P1mpSlap &raquo;</TD></TR><TR><TD CLASS="quote">In that picture, I think he has the stands on the front tow hooks, and the actual jack on the core support (not recommended!!).</TD></TR></TABLE>
The front tow hooks are farther up front and farther to the sides.
Old Jun 29, 2003 | 04:01 PM
romeo619romeo's Avatar
Default Re: (96dc2)
you can place the jack stands on the part where the LCA connects to..i think its called lca to rack join
Old Jun 29, 2003 | 04:18 PM
migs's Avatar
Default Re: front jacking point (.RJ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ &raquo;</TD></TR><TR><TD CLASS="quote">gawd... if youd' bother to go outside and look at your goddamn car you'd see hte jacking point. It is *not* on the core support (not to mention it would bend under the weight of the car) and they're not called "tow hooks" under the doors, its a jack(ing) point.</TD></TR></TABLE>
LOL, RJ, you grouchy or somethin man? Seems you always get upset because people get their terminology wrong. Anyhow, good information
Old Jun 29, 2003 | 06:05 PM
J337_UNIT's Avatar
Default Re: front jacking point (Migs)
that is the same spot (in the photo) that i jacked my car up when i put my header in. theres a metal tab that sticks down right under the radiator which is meant to use for a jack.
Whatislove
Honda Civic (2001 - 2005)
16
Jun 17, 2009 08:11 AM
b16egsi
Oct 27, 2003 11:45 AM
dclub01
Aug 18, 2003 04:21 AM
serious
Aug 21, 2002 08:24 AM
JL 74
May 3, 2002 09:26 AM
