Engine Misfiring! CEL code 71,72, and 74. What do I need to fix?
Old Jun 30, 2003 | 08:47 PM
TurboTurtleGSR's Avatar
Default Engine Misfiring! CEL code 71,72, and 74. What do I need to fix?
My CEL light came on saying that my car is misfiring in the 1st, 2nd, and 4th cylinder. Does anyone know what this means? Do I need new spark plugs/wires? I did a search on this, but no one ever figured out what the problem was? How do you know if you have a bent valve or bad injector? Thanks!
Old Jun 30, 2003 | 09:19 PM
threatcon13's Avatar
New User
Default Re: Engine Misfiring! CEL code 71,72, and 74. What do I need to fix? (TurboTurtleGSR)
are you boosting right now? when similar codes went off on my car, it was because the 3rd and 4th piston had chunks missing out the top and the rings were broken.
Old Jun 30, 2003 | 09:37 PM
One Bad GeeSeeR's Avatar
do a compression test and also a leak down test. thats a great place to start
Old Jun 30, 2003 | 09:50 PM
dohc-nyne's Avatar
my freind had the exact same code...and he changed spark plugs and reset ecu and it went away...i personally think he just had a loose spark plug...
Old Jul 1, 2003 | 08:53 PM
Default Re: Engine Misfiring! CEL code 71,72, and 74. What do I need to fix? (Threatcon13)
No, not boosting. It is all NA.
Old Jul 1, 2003 | 09:06 PM
Burglar's Avatar
Default Re: Engine Misfiring! CEL code 71,72, and 74. What do I need to fix? (ChampwhiteSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ChampwhiteSi &raquo;</TD></TR><TR><TD CLASS="quote">do a compression test and also a leak down test. thats a great place to start</TD></TR></TABLE>
Smart Guy. I had that same problem after I rebuilt my motor. I replaced the whole distributor, wires, etc........and finally did a leakdown test. Turns out I had 3 bent valves.
Old Jul 2, 2003 | 02:16 PM
iiilgsrlll's Avatar
I have the same problem with my car but I'm boostin and using Iridium plugs. The weird thing is that the light comes and goes. My compression is fine with 210's across all 4 cylinders. You may also want to check your crank pulley and make sure its not wobbling like mine.
I believe the CKF (crank speed fluctuation) sensor is mounted right next to the crank pulley and can trigger misfire CEL's if your pulley is doing what mine is doing. Good luck.
Old Jul 2, 2003 | 03:13 PM
Default Re: Engine Misfiring! CEL code 71,72, and 74. What do I need to fix? (iiilgsrlll)
Ok, I'll take a look at it. Hope it is nothing major.
Old Jul 2, 2003 | 03:14 PM
When you have a bent valve, does the engine make a obvious noise or you can't really tell by listening to it?
thanh4o8
Dec 8, 2009 08:18 PM
CUTTERSPOOL
Jun 16, 2009 05:11 PM
Avtarios
Oct 20, 2008 03:09 PM
phoshyzzle
Jun 9, 2008 11:03 AM
