cable to throtle body
Old Jun 29, 2003 | 01:47 PM
tegrunner's Avatar
Default cable to throtle body
is it true that you should check you throttle body cable to see if it is a little loose
someone told me that tegs do this
Old Jun 29, 2003 | 02:47 PM
Irritated_Onion's Avatar
Default Re: cable to throtle body (tegrunner)
All you need is two 12mm wrenches or even a crescent, and you can remove the slack in your throttle line.
Old Jun 29, 2003 | 03:31 PM
Regular Series's Avatar
Default Re: cable to throtle body (Irritated_Onion)
But, do it carefully! The Integra needs a small amount of slack in the throttle cable. If it's too tight, the car will idle high. I believe that the cable should have roughly 1/2" of deflection (check your service manual). HTH.
2k1TypeR0610
Oct 25, 2001 03:46 PM
Ibuprofen
Oct 7, 2001 08:34 PM
