e-brake light problem
Old Sep 7, 2004 | 07:24 PM
Dark_Seraph_X's Avatar
Default e-brake light problem
i drive a 2001 gs-r and i've recently had a problem with the e-brake light in the console. everytime i start my car up, even after i've released the emergency brake, the light remains on. even after examining the brakes, it doesn't appear to be engaged at all and there hasn't been any apparent rotor or pad damage on the rear brakes. after a couple miles of driving, the light just turns off. this problem only seems to occur when it's cold. any ideas? this is my first time posting here so any suggestions would be helpful.
Old Sep 7, 2004 | 07:28 PM
jdm_cars's Avatar
Default Re: e-brake light problem (Dark_Seraph_X)
take off your armrest.
there is a switch hooked up to a green wire under there.
unplug it, do you see the brake light turn off?
if it does, your switch is bad.
or leave it unplugged so the light will never turn back on.
Old Sep 7, 2004 | 07:33 PM
Your Epitaph.'s Avatar
///M Power
Default Re: e-brake light problem (jdm_cars)
Change your brake fluid.
Old Sep 7, 2004 | 07:38 PM
ekdriven's Avatar
i have 2000 gsr same problem but i need new breaks. i thought that might be the problem im gettin new ones when i get it out of shop.
Old Sep 7, 2004 | 08:50 PM
01DC-2's Avatar
Default Re: e-brake light problem (-MCMLXXXV-)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -MCMLXXXV- &raquo;</TD></TR><TR><TD CLASS="quote">Change your brake fluid.</TD></TR></TABLE>
same thing happened to me.
Old Sep 8, 2004 | 04:16 AM
Mazinger's Avatar
Default Re: e-brake light problem (01DC-2)
Replacing brake fluid.
I hope this is the problem.
My 00 GSr does this too. Especially in cold weather.
If I unplug the armrest switch the light still comes on. The reservoir is also full.
Old Sep 8, 2004 | 04:34 AM
jdm_cars's Avatar
Default Re: e-brake light problem (Mazinger)
then is the float on your Master Cylinder Resevoir working?
I would check the connectors (the ones in the two black connectors) to see if they have any corrosion on them, if so clean them off and put some di-electric grease on it.
Old Sep 8, 2004 | 04:46 AM
Radon_03's Avatar
go up to the resevoir and pull the connector off the cap and your problem will dissapear. This kept happening to me. Although this is not the best fix, it works. My car is USDM, but I dont see why it wouldnt work for a JDM car as well... correct me if im wrong.
Old Sep 8, 2004 | 11:38 AM
highrevin2k's Avatar
Default Re: e-brake light problem (Radon_03)
Same thing happenes here, But it went away after i replaced the brakes. But i dont think that was why it was on cause the brakes still had alot of meat on them. I think its just a factory flaw. Cause my brake fluid was full aswell. Seems to only happen with the 2000 and 2001 models
Old Sep 8, 2004 | 11:57 AM
reliablefrank's Avatar
Default Doesn't ONLY happen to '00-'01 models
I have a 94 LS and my brake light stays on sometimes too.
It usually only happens to me when the stupid AEM caliper bracket screws come loose and I have to take everything apart to retighten them in a hurry.
I always forget to release the ebrake before I try to disconnect the ebrake lines.
I second all of the advice posted here unless you have recently changed your rotors or something in which you had to disconnect your ebrake lines. In that case get down there and check them. Unfortunately when your disconnecting the ebrake lines you HAVE to release the ebrake even if you're on jack stands. It's dangerous but necessary.
This is all info from my personal experience but I am in no way an expert.
Old Sep 8, 2004 | 12:25 PM
O3ASEVO's Avatar
I have a 99 and this happens to me too. Only when i dont drive the car for a day then go to drive it the next day or when it's cold. It's an on and off thing for me though. I would also suggest changing the brake fluid.
Ryan
Old Sep 8, 2004 | 12:35 PM
pnthr30's Avatar
Default Re: (SlammedDC4)
This is a pretty common problem.......try searching the archives for some suggestions (most are really simple). More than likely, it is nothting, but better safe than sorry.
Old Sep 8, 2004 | 01:30 PM
gsrboi80's Avatar
Default Re: (pnthr30)
That wierd it happened to mine a couple times 1 rst time I took it to the dealer they fixed it under warranty second time I put more brake fluid in and it went away
Old Sep 8, 2004 | 06:56 PM
53JDMDC2's Avatar
I had the same problem but only on colder mornings. I found that if you slap the top of the master cylinder it turns off. I also have changed my brake fluid since then and no more problem. Dont need to remove your armrest.
Old Sep 9, 2004 | 02:01 AM
kelly's Avatar
Default Re: e-brake light problem (53DC2)
There is a TSB concerning this problem: http://www.team-integra.net/fo...on=83
Old Sep 9, 2004 | 11:58 PM
thanks for the suggestion, i'll try changing the brake fluid first and, if need be, try the armrest suggestion. much appreciated!
Old Sep 10, 2004 | 03:41 AM
Mazinger's Avatar
Default Re: (Dark_Seraph_X)
I took off the filter, for a test, and the light doesn't come on anymore.
Old Sep 10, 2004 | 05:07 AM
IntegraLova's Avatar
Default Re: e-brake light problem (highrevin2k)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by highrevin2k &raquo;</TD></TR><TR><TD CLASS="quote"> Seems to only happen with the 2000 and 2001 models</TD></TR></TABLE>
Incorrect. I have the same problem on my 99ls
Old Sep 10, 2004 | 06:25 AM
Mazinger's Avatar
Default Re: e-brake light problem (IntegraLova)
The e-brake light service bulletin applies to integras 97-01.
JDMmovement
Apr 26, 2008 08:50 PM
Jeff
Nov 22, 2006 03:45 AM
ponzarelli
Dec 30, 2002 10:42 PM
joel
Dec 21, 2001 11:38 AM
