Do i need a camber kit?
Old Sep 7, 2004 | 11:01 PM
no show no go's Avatar
Default Do i need a camber kit?
I just purchased H&R sports for my integra and i was wondering if you guys think i'll need a camber kit. My friend showed me a great trick to use on my rear wheels and says it works flawlessly.
http://home.earthlink.net/~civ....html
So i guess my question is do you think i'll need a camber kit for my front.
Drop: 1.75" or if you have any experience in this area.
Your help is greatly appriciated.
thanks.
Old Sep 7, 2004 | 11:13 PM
Accord2NR's Avatar
Default Re: Do i need a camber kit? (no show no go)
if it worked for your buddy then give it a try, but if you dont wanna wear out your tires faster, then get some
Old Sep 7, 2004 | 11:38 PM
MR-MUGEN's Avatar
the thing you are talking about for the back work and for the front ya go get a camber kit , my car is dropped 3" in the front and 3 1/4 in the back and my camber kit work i love it , been on my tires for about 8 months and hardly any wear
Old Sep 7, 2004 | 11:40 PM
yodas-gsr's Avatar
Default Re: (jdm92daintegra)
yea you should get a camber kit for the front ones, the back trick is a nice one eh!
late,
yoda
Old Sep 8, 2004 | 01:01 AM
jojoforhelp's Avatar
Default Re: (yodas-gsr)
With that mild of a drop, you dont need a camber kit. You will however need an alignment.
Its a very common misconseption that camber wears tires badly. Toe is the #1 tire eater.
I have run as much as 2.2* (for 4 months) camber and had very little camber wear. I now run 1.7 and no problems. Ask for the toe to be set 1/16th" out on each side.
Old Sep 8, 2004 | 06:47 AM
97CWITR's Avatar
Default Re: (jojoforhelp)
Have H&R sports on for about 4 months now. No camber kit...just an alignment.
Doin' just fine
Old Sep 8, 2004 | 06:56 AM
Honda Hick's Avatar
A 1.75" drop will noticably affect camber and it will eventually eat your tires. Sure it won't eat them like when your toe is off, but it still does affect wear. For your vehicle to ride correctly I would suggest that washer trick (I used it on my car and it works great) and then get a front camber kit online for like $80.
Old Sep 8, 2004 | 09:34 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Do i need a camber kit? (Honda Hick)
I rode on my last set of tires for 40K miles, ~3" drop on H&R Sports (yes Sports, yes it was a 3" drop, don't ask me why, H&R Sport springs suck @$$ IMHO), -2.5 camber in front, -2.0 in back, toe in spec at all times.
Old Sep 8, 2004 | 12:03 PM
Default Re: Do i need a camber kit? (PatrickGSR94)
so i guess more of you say i don't really need one for a 1.7 inch drop which is a good thing. it'll save me some money. if any else of you have an opinon please add it. Thanks!
Old Sep 8, 2004 | 01:08 PM
RallyRedGT-V6's Avatar
here's my experience with HR Sports
when i installed them..car tracked ok, and didn't pull too much, so i was like whatever, i dont feel like dropping 80 more dollars for an alignment [only place that would work on lowered cars charged 80...bastards]
well anyhow...4 weeks later...tires were absolutely gone, and this is all local >5 mile trips, i was at college, and just didnt look at my tires that much, till one day i left the wheel cocked all the way to the left and saw my belts...
well i didnt have the money for a camber kit...so i got my toe set straight [which was way the **** off...but almost dead even on both sides...which is why it tracked pretty straight]
9000 miles with -3 camber...zero uneven wear...
just get your alignment done
Old Sep 8, 2004 | 06:07 PM
Community Builder
Default Re: Do i need a camber kit? (96integra)
well it will start showing wear with THAT much camber... at -2.5 my tires started showing wear around 15K miles, so I flipped them around on the wheels to get more life out of them because I couldn't afford new tires at the time.
Now with GC's I'm probably going to get adjustable control arms front and rear so I can dial in my camber to around -2 in front and -1.5 in back.
Old Sep 8, 2004 | 07:43 PM
hotsuma23's Avatar
Hey guys, im considering a relatively considerable drop, not quite slammed y0 But maybe like 2.0-2.5 inches. Something that a "race" spring would give, like the h&r or neuspeed. I dont mean to thread hijack, it is on topic. Now my question is, generally, after what amount of drop would one need a camber kit, so that you wont have unnessecary tire wear?
Thanks,
Ben
Old Sep 8, 2004 | 09:29 PM
thanks for your guys help! don't know what i would do with out all you smart experienced people.
aloha,
-jordan
Old Oct 21, 2004 | 08:35 PM
I'm running with my stock 14" wheels that came with my LS and I just lowered my car today. Somone replied and said to "Ask for the toe to be set 1/16th" out on each side." What exactly is that? Do you guys recommend that too? Your input would help. aloha
-jordan
Old Oct 22, 2004 | 01:00 AM
yeegsr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm92daintegra &raquo;</TD></TR><TR><TD CLASS="quote">the thing you are talking about for the back work and for the front ya go get a camber kit , my car is dropped 3" in the front and 3 1/4 in the back and my camber kit work i love it , been on my tires for about 8 months and hardly any wear</TD></TR></TABLE>
hardly any wear...take some hard corner at 20mph or 25, or 30....your tires will last for 1month lol
lowering wears out tires most at cornering with some speed
Old Oct 22, 2004 | 04:50 AM
dip-set's Avatar
Default Re: (yeegsr)
hers my camber wear after about 6-7 months of ridin on h&r sports mated with kyb agx's toe and thrust angle was set 0 front camber was over -2 degrees and rear was about -2 degrees
plug: this car was stolen from passaic new jersey monday night/ tuesday morning...10-18/19-2004...
Old Oct 22, 2004 | 06:50 AM
TegRyder33's Avatar
no I have them myself and im fine its nto a huge drop
Old Oct 22, 2004 | 07:18 AM
94gsr_vtc's Avatar
Default Re: (TegRyder33)
yes no need for a camber kit just get it ALIGNED properly! i have these springs with no problems. unless you have a steady cash flow, dont get one
Old Oct 22, 2004 | 07:51 AM
Googs16's Avatar
Default Re:
I've had my H&R's installed for almost a year now with no camber kit and no wheel alignment and i haven't noticed any unusual tire wear.
Sorry i don't have a pic (i'm posting from work)
Old Oct 23, 2004 | 11:23 PM
yeegsr's Avatar
Default Re: (b18b-se)
dann nice *** man..ur avator is tight...can i spank it?
clutch33
Oct 29, 2003 04:54 PM
im_the_teacher
Sep 20, 2003 11:25 PM
IloveNewt
May 5, 2003 10:24 AM
taytay333
Nov 17, 2002 07:13 PM
VTECTIME
Sep 11, 2002 04:04 AM
