lowering spring problems...
Old Sep 6, 2004 | 12:55 PM
Dee A Nine's Avatar
Default lowering spring problems...
Alright, I lowered my friend's car right, but when we dropped it, and while he turns, there's this weird snap of the spring. He's fastened all the bolts and all that other ****. Is it because he has to break it in or something? I just want to know if it's normal or not. Thanks for any input guys. HT = Great place for knowledge.
Old Sep 6, 2004 | 01:00 PM
PLAGUED_DB7's Avatar
Default Re: lowering spring problems... (Dee A Nine)
is it in the back of the car or the front?
When I got my sportlines I noticed my car would do that..it went away after some wd40 and a couple hours of driving. (It was the back btw)...good luck..
Old Sep 6, 2004 | 03:24 PM
Dee A Nine's Avatar
Default Re: lowering spring problems... (theplague83)
it's in the front... we kinda fixed it now... but at the end of the 3rd left turn it makes a squeeky rubbing sound... what's that now?
Old Sep 6, 2004 | 03:31 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dee A Nine &raquo;</TD></TR><TR><TD CLASS="quote">it's in the front... we kinda fixed it now... but at the end of the 3rd left turn it makes a squeeky rubbing sound... what's that now?</TD></TR></TABLE>
rubbing isnt good...could be the wheel hitting the springs??
Old Sep 6, 2004 | 03:47 PM
VTECrazed's Avatar
Well if its doing that than I would guess tire rubbing the fender well. It's the most common when vehicles are lowered too much. Also sometimes when a vehicle is lowered by just springs sometimes you hear a loud snap sound because the spring wasn't seated all the way against the pillow ball upper mount. Common no worry. Also a squeking rubbing sound could be the upper mount gasket worn out or the the springs themselves rubbing together when they compress down when you make your turn.
Old Sep 6, 2004 | 11:30 PM
laezpnai's Avatar
Default Re: lowering spring problems... (VTECrazed)
was it like a thump? mines kinda like a thump. could this be the same thing? ive gotten answers in other threads, but just thinkin.. *sportlines* and its in the front, tight left turns only..
Old Sep 9, 2004 | 06:48 PM
Dee A Nine's Avatar
Default Re: lowering spring problems... (laezpnai)
hmm... not really sure... just.. like... iono... stupid coilovers
Old Sep 9, 2004 | 07:37 PM
boosted k20's Avatar
did u install a camber kit when u lowered his ride? when i dropped my car and installed a set of camber kits (the ingalls style), it moved the upper control arm (UCA) closer to the frame next to the fender. the upper control arm was resting right below the frame and when i took it for a drive and hit a small pot hole, i heard a loud metal banging sound. the sound came from the upper control arm hitting the frame and denting it a little bit. no serious damage was done though, just a little dent. i apparently put too must postive camber which pushed the UCA closer to the fender. i just adjusted the camber kit to give it less positive camber and it stopped the problem.
if u dindt have a camber kit installed then i dont know. did ur friend buy a cheap camber coilover setup? maybe thats the culprit
Old Sep 9, 2004 | 07:39 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">rubbing isnt good...could be the wheel hitting the springs??</TD></TR></TABLE>
the wheel hitting the spring?????? damn, if that happens then ur car must be dropped like over 3 inches. i dont think the wheel could hit the spring.....
Old Sep 12, 2004 | 11:20 AM
Dee A Nine's Avatar
Default Re: lowering spring problems... (boosted k20)
naw naw, it's not hitting anything, it's just like, while he turns, he hears a "dub'' sound, but that's only when he's turned left alot... kno what i mean?...
Old Sep 12, 2004 | 11:23 AM
Dee A Nine's Avatar
it couldn't have been lowered that much, they're sport H&R springs... even the fools at Super VIP said it wouldn't make that much of a difference in lowering and it shouldn't be any problem either..
boostedcivicsir
Apr 10, 2007 02:27 PM
george34
12
Jun 26, 2006 12:54 PM
DC2IntegraTypeR
Suspension & Brakes
13
Feb 14, 2005 04:07 PM
Carlito Brigante
11
Apr 17, 2004 07:10 PM
NuclearB18B
Mar 25, 2003 03:28 PM
