ABS Light
Old Sep 8, 2004 | 06:43 PM
xdavidx's Avatar
Default ABS Light
i know its been covered, but i came with information and just wanting to know how to go on by and fixing it.
so i got ABS flashing codes info from this thread: https://honda-tech.com/zerothread?id=941971
i have a 96 gsr so those info would go with my car since he said 98 and up integs are different.
so i did everything and got the flashes. so the flashes that i got was 3 fast flashes that could mean i have
1 2 ABS pump motor
2 1 parking brake
im going to go run the check again to see if i can see which one it is. somebody help me on what i should do with either of the two things i've listed, thank you
edit: ok so i checked it again and i think i got 1-2 the ABS pump motor because i got the intial lighting of the ABS when i turned the key and then after that went away it flashed and the pause after that seem longer then the pause between the 2nd and 3rd flash. so would that mean i have what i think i have? anyhelp on either on would be helpful thx guys
Old Sep 8, 2004 | 08:24 PM
xdavidx's Avatar
Default Re: ABS Light (xdavidx)
bump for some answers
Old Sep 9, 2004 | 01:41 AM
xdavidx's Avatar
bump for the night
Old Sep 9, 2004 | 04:27 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xdavidx &raquo;</TD></TR><TR><TD CLASS="quote">so i did everything and got the flashes. so the flashes that i got was 3 fast flashes that could mean i have
1 2 ABS pump motor
2 1 parking brake
</TD></TR></TABLE>It depends on the spaces between flashes. Like this...
flash-(1second pause)-flash-flash = 1 - 2
flash-flash-(1second pause)-flash = 2 - 1
Also, remember don't count the first long flash & long pause.
1 - 2 is the pump motor. I'd look at its circuit for problems, before getting a new($$) motor.
2 - 1 is for the parking brake signal. Having trouble with your parking brake warning light? When that's on, it disengages the ABS or something like that. So make sure your handbrake switch is OK, along with the float switch in the brake fluid reservoir.
Old Sep 9, 2004 | 11:07 AM
SlowGreenEJ's Avatar
sorry to chop thread but what if it stays on all together and doesn't go off?
Old Sep 9, 2004 | 11:11 AM
timmy8151's Avatar
Default Re: (SlowGreenEJ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SlowGreenEJ &raquo;</TD></TR><TR><TD CLASS="quote">sorry to chop thread but what if it stays on all together and doesn't go off?
The ABS light should be solid. It only flashes, once the service connector has been jumped.
jrmullins85
Sep 24, 2015 05:40 AM
Marcg611
Sep 19, 2009 01:14 PM
m00nr0ck Si
May 25, 2009 09:33 AM
Bsharpe
May 8, 2009 03:33 AM
DubFat
Apr 15, 2005 10:04 PM
