Integra cluster?
Old Sep 6, 2004 | 07:47 PM
Black Raven
Guest
Posts: n/a
Default Integra cluster?
I already did a search but all came up with JDM ITR clusters. Anyways i want to know if the USDM 97-01 ITR cluster work with my 94 GSR?
Old Sep 6, 2004 | 07:59 PM
njandrewg's Avatar
Default Re: Integra cluster? (AiKwuJiTong)
yes but it'll work but ur redline w/ill still be not as high
Old Sep 6, 2004 | 08:20 PM
Black Raven
Guest
Posts: n/a
Default Re: Integra cluster? (njandrewg)
haha, true true
Old Sep 6, 2004 | 08:28 PM
undagroundrican's Avatar
yo i was told that you would have to remove the green sheet on the back of the type r cluster and put your green sheet from a 94 to work
example i have a 94 and i brought a 01 cluster i plugged it in and the tach was jumping kinda wierd i dont think the plug ins are the same even though they do plug right in.
Old Sep 6, 2004 | 08:33 PM
Black Raven
Guest
Posts: n/a
Default Re: Integra cluster? (undagroundrican)
hmmmm...interesting. Thanks for the info. I used to have a 2000 civic ex and swap in a JDM CTR cluster and work fine, but i guess integras are different.
Old Sep 6, 2004 | 08:38 PM
esponet's Avatar
94-97 will work no problem, 98-00 are different. but you could re-pin your cluster pin-conections, so that it will work ok. if the 98 cluster came with the plug, just match the colors/pin connections on your car. imo this is easier than switching housing,green film,guages,
Old Sep 6, 2004 | 10:38 PM
Mr.DC2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by njandrewg &raquo;</TD></TR><TR><TD CLASS="quote">yes but it'll work but ur redline w/ill still be not as high </TD></TR></TABLE>
redlines are just a guideline. if and when he does rebuild, he can raise his redline to whatever he pleases as long as his motor can do it.
Old Sep 6, 2004 | 10:43 PM
hammerdgolfer's Avatar
yes you can change the rear green panel of the cluster to make any cluster work in there,
clusters wont work perfectly if you have a 94-95(obd1) car and put a 99-01 cluster in it(obd2b) and obd2 is 96-98 yo
wesmac
Honda Civic (2001 - 2005)
Mar 23, 2017 07:43 PM
StReCh4130
Feb 28, 2008 09:44 AM
darrinbrewer
Feb 26, 2005 03:01 PM
:jdmshmaydm:
Apr 29, 2003 04:13 AM
