Header question
Old Sep 6, 2004 | 10:15 PM
s2k_al's Avatar
Default Header question
Will a header for a 94 GSR fit a 94 LS
Old Sep 7, 2004 | 12:03 AM
92integra_gs's Avatar
i know you got a crx but wouldnt be this a better question to ask in the integra question?
to try answering your question tho.... i dont think it would.... in terms of the header that you are trying to fit is from a different block... and that vtec block have bigger exhaust bores than nonvtec block...
Old Sep 7, 2004 | 04:36 AM
Home Skillet's Avatar
Default Re: Header question (c_rex88)
The header will bolt up to the exhaust ports but the length will have to be modified. I had a header from an LS motor and swapped it onto my B16 with no problems except for it not being long enough.
Old Sep 7, 2004 | 09:32 AM
DSR!'s Avatar
Default Re: Header question (Home Skillet)
Home Skillet
WHat He said
Old Sep 7, 2004 | 09:37 AM
Sack Master's Avatar
Default Re: Header question (DSR!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Home Skillet &raquo;</TD></TR><TR><TD CLASS="quote">The header will bolt up to the exhaust ports but the length will have to be modified. I had a header from an LS motor and swapped it onto my B16 with no problems except for it not being long enough. </TD></TR></TABLE>
By not long enough he is referring to the legnth of the collector. It will fit just fine.
little B
May 3, 2007 10:25 AM
93h22a1vtec
Jan 11, 2006 06:21 PM
s2k_al
Sep 7, 2004 07:41 AM
